Recent Activity
Activity stream for all registered members at PriusChat.
jerrymildred replied to the thread EGR/Intake Service on 2013 Prius.
Yup. Just ignore it.
May 27, 2024 at 2:30 PM -
bisco replied to the thread Newbie here.. Help, 2021 Prius bottomed out on tank cap in gas station.
wrong scanner. take it to a dealer, or diy with mini vci, tech stream and laptop. that takes some tech savvy. could be coincidence, but...
May 27, 2024 at 2:25 PM -
Mike Ireland liked KH111's post in the thread Is Gen 5 Prius really better-looking than Gen 4 Prius Prime?.
In answer to the original topic I think the Gen 5 is so much better looking now vs previous generations. I did not really consider a...
May 27, 2024 at 2:23 PM -
Tombukt2 replied to the thread EGR/Intake Service on 2013 Prius.
That is called Bear plastic and on your 2013 there's nothing that goes there You are good to go carry on
May 27, 2024 at 2:20 PM -
Tombukt2 liked jerrymildred's post in the thread EGR/Intake Service on 2013 Prius.
Wow, people over complicate this job. I've don'e this lots of times. The only thing that's actually hard is removing & replacing the...
Tombukt2 replied to the thread Questions about Bleeding Brakes with Techstream.
Pretty much there you go I don't usually have the hybrid battery plug out and usually I don't even undo the 12 volt I just keep the...
May 27, 2024 at 2:19 PM -
Tombukt2 liked rogerthat's post in the thread Questions about Bleeding Brakes with Techstream.
Successful bleed! Here's what I did: 1: Without connecting the 12V, I performed a manual brake bleed - got some air/fluid out of the...
May 27, 2024 at 2:18 PM -
hill replied to the thread Is Gen 5 Prius really better-looking than Gen 4 Prius Prime?.
At 6'-5" & 220 Lbs, I have to do the butt swivel entry too - on our Chevy Volt - which is similarly too low in stature for us...
RandyPete liked Yvrdriver's post in the thread Gen 5 maintenance demos on YT.
Came across this youtuber doing prius gen 5 maintenance: oil change, filter change, battery replacement, etc 2023-2025 Toyota Prius...
May 27, 2024 at 2:15 PM -
dbstoo replied to the thread Is Gen 5 Prius really better-looking than Gen 4 Prius Prime?.
Just to throw out another experience... I'm 5'11 and 210 lbs. Before buying the 2024 model I visited a local dealer where I "test...
May 27, 2024 at 2:13 PM -
hill replied to the thread One of these things is not like the other.
I often feel sorry for dual cab long bed pickups trying to navigate through narrow parking lots - trying to find a close-up spot rather...
May 27, 2024 at 2:09 PM -
sylvaing attached a file to the thread TPMS throws errors after driving for a while.
So, my go to mechanic shop told me to go to the dealership since they'll charge me 0.5 hour of work and will come out more expensive...
May 27, 2024 at 2:04 PM
