Recent Activity
Activity stream for all registered members at PriusChat.
Mr.Vanvandenburg replied to the thread About Ukraine and F16s.
It is not political. I understand what President Biden said because I said the same thing to myself before he said it. What are they...
May 26, 2024 at 12:40 PM -
Rbjr replied to the thread reset check engine light.
Thank you for the procedure to reset the check engine light.. I think the trip needs to show the odo for the dashes to happen?? I had...
May 26, 2024 at 12:39 PM -
Mendel Leisk replied to the thread Tires and the Prius.
Both the 17" and 19" gen 5 tires are only 195 mm width IIRC. Makes it kinda hard to up the tire height, if you want to maintain the same OD.
May 26, 2024 at 12:24 PM -
Mendel Leisk replied to the thread Brakes slam/thumping after hubs replaced..
Sounds coming from front, back, hard to tell? You've looked all the calipers over thoroughly? First thought is someone forgot (or...
May 26, 2024 at 12:20 PM -
Mendel Leisk replied to the thread Something missing here....
To prevent return visits, take off the wipers and cowl, put some 1/4" (opening size) galvanized steel mesh over the cabin air intake....
May 26, 2024 at 12:13 PM -
Jeff606 replied to the thread Car Wash Mode.
It's called a "Drive through automatic car wash"
May 26, 2024 at 12:11 PM -
Mendel Leisk attached a file to the thread The Dog Thread.
Our shiba was sprawling by our outside table at the coffee shop; he reminded me of something: [ATTACH]
May 26, 2024 at 12:09 PM -
Jeff606 replied to the thread Tires and the Prius.
I had a 2009 Prius Touring Edition with 185/45 R16 tires. Not excessively low profile, but ugh! It was not the most comfortable ride at...
May 26, 2024 at 12:05 PM -
Mendel Leisk replied to the thread Purolator still considered not so great?.
I was idly wondering about the delivery service connection. Purolator Inc. - Wikipedia.
May 26, 2024 at 11:55 AM -
fiz replied to the thread Direct wiring for DashCam / other devices.
Thanks, I found this website: Fuse Box Diagram Toyota Prius (XW30; 2010-2015) and [MEDIA] Do you know which ones are always powered on...
May 26, 2024 at 11:48 AM -
BiomedO1 replied to the thread New Toyota Prime Gen 5 - Storage and Battery Maintenance for 2-3 Weeks.
1. make sure your manual keys works 2. Pop the hood and find your jump points - alternatively find your battery door in the trunk. 3....
May 26, 2024 at 11:47 AM -
PTS replied to the thread 2012 Prius V Signal switch wiring Diagram and color code.
Quiet
May 26, 2024 at 11:42 AM -
Tombukt2 replied to the thread Direct wiring for DashCam / other devices.
There's a fuse box right in about the same location just above your left knee and a left hand drive car is a fuse box that you could...
May 26, 2024 at 11:37 AM -
Paul Gregory replied to the thread New Toyota Prime Gen 5 - Storage and Battery Maintenance for 2-3 Weeks.
The 12 V battery draining had always been a concern for me with my 3rd Gen Prius. I once left it for 3 weeks, and I had a difficult time...
May 26, 2024 at 11:24 AM
