Recent Activity
Activity stream for all registered members at PriusChat.
mohater replied to the thread Questions on rebuilding hybrid battery, make sure I'm on the right track.
Thanks, just needed the value. Time to order, replace, torque and see what happens.
May 26, 2024 at 10:34 AM -
mohater liked ColoradoCrow's post in the thread Questions on rebuilding hybrid battery, make sure I'm on the right track.
48 inch pounds..... yes....Toyota states 48 inch pounds for the module fasteners, which includes the positive/negative terminals and...
zoeboi954 replied to the thread how do you find what trim level you have on your prius.
awesome i have a level 5, leds with adaptive cruise. Thanks so much
May 26, 2024 at 10:30 AM -
mr_guy_mann replied to the thread ABS, VSC (!) light on but brakes work fine, except for the anti lock.
You would benefit from having a capable scantool. Here's a thread that reviews several apps and devices....
May 26, 2024 at 10:29 AM -
HacksawMark replied to the thread Is Gen 5 Prius really better-looking than Gen 4 Prius Prime?.
Allocations are a lot different than actually ordering a vehicle from the factory with $$ involved. That plus the time involved for the...
May 26, 2024 at 10:28 AM -
mr_guy_mann attached a file to the thread 2009 Prius - Warnings and will not engage..
As long as there is no corrosion at the orange connector of your battery ecu, you should have no problems. Take before and after pics...
May 26, 2024 at 10:26 AM -
MikeDee liked ForestBeekeeper's post in the thread TOYOTA HYBRIDS.
If one car out of every 10,000 has a head gasket issue, I would not call that an 'inevitable' problem. I drive a 2011 Gen 3 with over...
May 26, 2024 at 10:23 AM -
ColoradoCrow replied to the thread Questions on rebuilding hybrid battery, make sure I'm on the right track.
HacksawMark liked rjparker's post in the thread Latest recall - sales stop!.
If you are owed the $35k to buy a car just strike while the iron is hot. The last thing you want is a gen3 with oil burning, head...
May 26, 2024 at 10:21 AM -
HacksawMark liked Mendel Leisk's post in the thread New Toyota Prime Gen 5 - Storage and Battery Maintenance for 2-3 Weeks.
Owners manual covers the jump start method. And location, but seriously: you need internet advice to find the battery? ;)
May 26, 2024 at 10:20 AM -
ColoradoCrow liked rogerthat's post in the thread Prepping for ABS Actuator Replacement.
Hmm, when I was doing my research, I recall the Thinkdiag Mini as just being a basic code-reading scannner, not capable of bidirectional...
May 26, 2024 at 10:19 AM -
tochatihu replied to the thread Texas Starship Testing.
Fourth test flight is scheduled for June 4 pending regulatory approval. Same flight plan as last time.
Cody Swain liked dolj's post in the thread Replaced abs actuator, getting constant beep, no warning codes, abs actuator hasn’t kicked on once..
You might be able to do limited bleeding to move fluid through the lines to each corner but you cannot bleed the actuator without...
May 26, 2024 at 10:09 AM -
Cody Swain liked jaotwox's post in the thread Replaced abs actuator, getting constant beep, no warning codes, abs actuator hasn’t kicked on once..
I also have a 2005prius with almost 400k miles. Im about to do a manual bleed as we speak because both rear drum brake cylinders started...
