Recent Activity
Activity stream for all registered members at PriusChat.
bwilson4web posted a new thread.
About Ukraine and F16s
IMHO, every rail road bridge within 200-300 km of the Ukraine border on the Russian side should be taken down. Target the repair crews...
Forum: Fred's House of Pancakes
May 23, 2024 at 2:47 PM -
Mendel Leisk replied to the thread High Coolant Temperature Warning Light.
Do you know which cylinders the ignition coils were changed on? Where I'm going: It's common for gen 3's and Prius v's which are...
May 23, 2024 at 2:45 PM -
bwilson4web replied to the thread Why we need emigrants.
Funny you mentioned this: Had Ford pardoned them along with Nixon, he would have had a second term. We had to elect Jimmy Carter to fix...
May 23, 2024 at 2:42 PM -
PriusCamper replied to the thread Regen on AWD model.
I think it has to do with load distribution and the fact that vehicle momentum during braking leans forward and puts 60% to 90% of the...
May 23, 2024 at 2:34 PM -
Tombukt2 replied to the thread P Lock C2310 Fix Fixed Solved Solution.
I have a car with a 2310 code and I think the 2300 both related to the actuator and the wife says the car's triangle was coming on and...
May 23, 2024 at 2:33 PM -
mountaineer liked Mendel Leisk's post in the thread (Pretty) Prius Prime first world problems! :).
Corded-electric Craftsman mower here, bought in a previous century IIRC. The deck is all steel. Our “lawn” is more and more moss, native...
May 23, 2024 at 2:31 PM -
Carlton W Terry replied to the thread High Coolant Temperature Warning Light.
There was a check engine light code, but I don't have that info in front of me.
May 23, 2024 at 2:28 PM -
Carlton W Terry liked Mendel Leisk's post in the thread High Coolant Temperature Warning Light.
Anymore info on that, say misfire codes?
May 23, 2024 at 2:25 PM -
Carlton W Terry liked Georgina Rudkus's post in the thread High Coolant Temperature Warning Light.
Sounds like a sticking or slowing rotor on the electric water pump.
Carlton W Terry liked Leadfoot J. McCoalroller's post in the thread High Coolant Temperature Warning Light.
These are warnings of serious problems- the engine is not likely to last a lot longer. Might already be time for a full replacement.
Mendel Leisk liked Hilary K's post in the thread Error code C1391. New anti-lock brake system?.
The warning lights on the dashboard have turned themselves off again and the buzzing/pump sounds less freqeuntly now (about every 10...
May 23, 2024 at 2:17 PM -
AnneN liked Leadfoot J. McCoalroller's post in the thread 12V 120w Socket.
Might be worth re-checking this. I'm assuming that "power generator" means a portable battery bank in this context. A battery bank that...
May 23, 2024 at 2:13 PM -
I took a look. From what I can see that thing can pull quite a lot in fast-charge mode, so you are on the right track to separate these...
AnneN replied to the thread 12V 120w Socket.
Completely agree. By the law of averages I am bound to walk away from the car without manually unplugging the equipment and totally kill...
May 23, 2024 at 2:12 PM
