Recent Activity
Activity stream for all registered members at PriusChat.
Tony Rico replied to the thread Gen 2 third party hybrid batteries.
I've had no luck finding online sources for new OEM Toyota gen 2 packs, just the rebuilders. Any clues? I'm in NW Michigan. Also, If I...
May 12, 2024 at 11:43 AM -
Tony Rico replied to the thread Gen 2 New OEM Toyota Hybrid Battery Replacment April 2023.
Also, I am in NW Michigan, if that helps point me to a reasonable dealership.
May 12, 2024 at 11:37 AM -
Anyone have a link where I can order the G951047031 gen 2 prius battery? I can't find any official online sources other than the...
May 12, 2024 at 11:35 AM -
sufyant replied to the thread Memory seat doesn't save correct vertical position.
I found this in the manual: The seat position may not be recalled in some situations when the seat position is recorded in a certain...
May 12, 2024 at 11:28 AM -
Approximate Pseudonym liked Hammersmith's post in the thread Okay. Who HASN'T had a 12V battery issue with their 2023-24 Prime?.
When you say trickle charger, I think what you actually mean is a battery maintainer. There's an important difference between the two. A...
May 12, 2024 at 11:25 AM -
ChapmanF replied to the thread Help request: Main Body ECU schematic?.
... and if the OP has measured a < 10 kΩ resistance to ground on that path inside the junction block, with the Body ECU removed and...
May 12, 2024 at 11:22 AM -
austingreen liked bwilson4web's post in the thread Tesla Autopilot recall probed by safety regulator following new crashes.
I've long suspected the NHTSA was looking at twigs on a tree instead of the forrest of how dangerous different car models are in real...
May 12, 2024 at 11:17 AM -
bwilson4web liked tochatihu's post in the thread Environmental News.
I joined there, but have not talked about why CO2 in eg. Mars does not trap heat well at that low density. It seems WRONG to interfere...
bwilson4web replied to the thread Tesla Autopilot recall probed by safety regulator following new crashes.
I've started analyzing the FARS data with the 2019 accidents involving Teslas: 40 accidents 15 fatalities This initial data allows...
May 12, 2024 at 11:15 AM -
Approximate Pseudonym liked Paul Gregory's post in the thread Okay. Who HASN'T had a 12V battery issue with their 2023-24 Prime?.
Today, the dealer thought resetting the wireless component of the system might resolve the parasitic drain. The battery replacement was...
May 12, 2024 at 11:08 AM -
Approximate Pseudonym replied to the thread Okay. Who HASN'T had a 12V battery issue with their 2023-24 Prime?.
NOCO Genius 10 Any of the Genius models should do the same job, I think.
May 12, 2024 at 11:07 AM -
Gokhan replied to the thread Anyone has achieved 63 miles EV Range (Gen 5 Phev) as in this video?.
SE should get ~ 66 mi and XSE/XSE Premium ~ 59 mi in gentle city driving. I get ~ 38 mi in my 2021 Limited.
May 12, 2024 at 11:03 AM -
I did but it's the same. Also weird that the video says the saved seats would clear after re-calibration but mine do not clear.
May 12, 2024 at 10:48 AM
