Recent Activity
Activity stream for all registered members at PriusChat.
  1. Ainsley liked ETC(SS)'s post in the thread fix or replace?.
    Yes. You're not throwing good money after bad but you might be throwing it in the wrong place. Three thoughts: 1. If you have the...
    Jun 5, 2024 at 10:47 PM
  2. Ainsley liked Tombukt2's post in the thread fix or replace?.
    Put a die-hard AGM battery in the 12 volt Toyota doesn't make batteries so buying them at the dealer doesn't really make sense they're...
  3. JohnPrius3005 replied to the thread HV Battery code P3000-389.
    You can build yourself a "grid" charger to charge the HV bat. For less than $100. Using this "might" buy you the time you want. Then you...
    Jun 5, 2024 at 10:26 PM
  4. Grit replied to the thread can I use this battery? LiFePO4 Battery as the 12V battery.
    Does the bms have low temp cut off?
    Jun 5, 2024 at 10:24 PM
  5. 16 yrs & counting replied to the thread Netting attachment won't stay in wall.
    I just dug into my old paperwork on this car and the "cargo net" came with package 7 on the 04 Prius.
    Jun 5, 2024 at 10:12 PM
  6. htcmember liked Tombukt2's post in the thread Can we do a software update after EGR cleaning job with TechStream.
    Yeah the steps are posted all around I mean it doesn't really do a whole lot I would say yeah you definitely want to make sure you're 12...
    Jun 5, 2024 at 9:30 PM
  7. htcmember liked Danno5060's post in the thread Can we do a software update after EGR cleaning job with TechStream.
    While I've not programmed a car's computer, I've got 20+ years of experience programming industrial controllers. There's always the...
    Jun 5, 2024 at 9:29 PM
  8. 16 yrs & counting replied to the thread Netting attachment won't stay in wall.
    Interesting! It's encouraging to hear that there might be an explanation. Maybe I'll try popping it off tomorrow to see what's under...
    Jun 5, 2024 at 9:28 PM
  9. htcmember liked wr69's post in the thread Can we do a software update after EGR cleaning job with TechStream.
    I have taken apart the EGR valve and dont recall any specific electronic parts in there. its a relatively dumb electro-mechanical...
    Jun 5, 2024 at 9:21 PM
  10. rjparker attached a file to the thread can I use this battery? LiFePO4 Battery as the 12V battery.
    It has a built in BMS to keep itself safe. The higher amp hour rating means it will discharge slower. Fit is an issue due to the...
    IMG_5279.jpeg Battery Isolator SBI12 2of4.jpeg IMG_5278.jpeg Jun 5, 2024 at 9:20 PM
  11. ETC(SS) replied to the thread Two questions....
    It's a little 'young' for my tastes, but then it's a vast improvement over the G4. Most cars are. I suppose that if you live in a place...
    Jun 5, 2024 at 9:19 PM
Loading...
