Recent Activity
Activity stream for all registered members at PriusChat.
Tater25 liked ChapmanF's post in the thread Horn Stopped Working.
If you hold the horn pad in the pressed position and turn the wheel around to different positions, does the horn beep in some places and...
Jun 7, 2024 at 7:06 PM -
Tater25 liked Jesse Melara's post in the thread Horn Stopped Working.
I found out what it was about 4 months ago by testing my panic button. Horn went off. Then one day when I turned my wheel and pressed...
Jun 7, 2024 at 7:05 PM -
Zythryn liked austingreen's post in the thread Gen 6 Prius engine will be a “game changer,” achieve a 53% thermal efficiency.
53% of course can be done with heat recovery (turbo charging but likely e-turbos). Mercedes first did this over a decade ago. The...
Jun 7, 2024 at 6:55 PM -
priuslyfe liked Tombukt2's post in the thread One of my Prius won't start (not started for 3 months) FIXED!! Wrong Spare Key.
Leave it on low now that that's that's no good If anything you'd have to come up with a way to apply the brake and put it in drive and...
Jun 7, 2024 at 6:41 PM -
Wow things are really that bad in that area of Ohio really I hate to hear that I guess that's why we don't drive out that way since the...
priuslyfe replied to the thread One of my Prius won't start (not started for 3 months) FIXED!! Wrong Spare Key.
OK, wait so you have to apply the brakes as well to get the HV to recharge? If that's the case I'll wait till around 1am and drive it...
Tombukt2 replied to the thread One of my Prius won't start (not started for 3 months) FIXED!! Wrong Spare Key.
Jun 7, 2024 at 6:37 PM -
Jun 7, 2024 at 6:35 PM -
Gokhan replied to the thread Gen 6 Prius engine will be a “game changer,” achieve a 53% thermal efficiency.
As I said, the vertical axis explicitly shows a break, but the horizontal axis is not showing a break; therefore, it is starting from zero.
Jun 7, 2024 at 6:31 PM -
villageboar replied to the thread HV Battery code P3000-389.
Given that the voltage is currently around 200, and then one of the blocks is showing 2 V, that adding a new block (two purchased cells)...
Jun 7, 2024 at 6:21 PM -
priuslyfe liked rjparker's post in the thread One of my Prius won't start (not started for 3 months) FIXED!! Wrong Spare Key.
The hybrid system only partially charges the hv battery when idling. The engineers must of thought no one would waste gas in a Prius by...
Jun 7, 2024 at 6:20 PM -
Drive the car I do this with cars without tags on them up and down my street all the time never a problem and I pull back in my driveway...
Jun 7, 2024 at 6:19 PM -
I am afraid to drive the car without tags/license because I suspect it will be one time I get pulled over for something. Plus Iive in...
