Turning off the beeping for RSA permanently + OBD programming app
Discussion in 'Gen 5 Prius Technical Discussion' started by mackosky, Apr 8, 2024.
  1. mackosky
    mackosky New Member
    Poland
    2025 Prius Plug-in
    I wanted to ask You if there is any way to get rid of the RSA above speed limit beeping permanently?
    Found some threads on internet but I can't see the 'normal' way for turning it off.
    So I have a follow up question, Is there any application or something else which gives ability to modify some options which are not given in normal HUD? (hidden features, advanved modes)
    Thanks in advance.
    Maciej
  2. deev
    deev Junior Member
    34
    usa
    2024 Prius Prime
    XSE Premium
    is it a country/region specific setting? In California, we don't get "beeps" like that.
  3. Hammersmith
    Hammersmith Senior Member
    1,218
    1,224
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Carista has finally been updated for the gen5, but it can't shut off the European RSA beeping. Technically it's only been updated for the Prius and not the Prius Prime/PHV, but it should be a good starting point.
    You can see what it can and can't do here: Carista
    At a glance, it seems to be the same stuff that can be changed at a Toyota dealership, but I didn't dig in to see if they're exactly the same. You can find all configurable options towards the end of your owner's manual under Vehicle Specifications -> Customization(section 9.2).
