Recent Activity
Activity stream for all registered members at PriusChat.
douglasjre liked MIkeDr's post in the thread Interior Noise Level.
Quieter but still loud. It’s too bad that Toyota didn’t sacrifice an mpg or two to add some sound dampening material.
Jun 14, 2024 at 11:41 PM -
douglasjre liked Cactus's post in the thread Interior Noise Level.
Curious what the interior noise level is at highway speeds? We own a 2014 Prius that my wife drives and it is pretty noisy on the...
Jun 14, 2024 at 11:40 PM -
douglasjre liked John321's post in the thread Just need to vent....
I do the grocery shopping for our family. I readily admit to being a penny pincher/cheapskate/ Coupon saver etc. My current savings for...
douglasjre liked Jon Vitrano's post in the thread Clean everything still knock when pressing on gas pedal.
Stilling running on the 4th engine. Hot weather is fine, no overheating. Getting about 55-56 mpg on the original 10 year old battery....
Jun 14, 2024 at 11:36 PM -
KitsuneVoss replied to the thread 2009 Prius - Warnings and will not engage..
It seems to be pretty steady for a week now with getting a combined total as far as MPG of between 48.2 and 48.4 mpg compared to 46.5...
Jun 14, 2024 at 11:34 PM -
ChapmanF replied to the thread HV fan preset overriding.
Or that they optimized it to a different objective function than you would choose. Still, even if you lay out your own choice of...
Jun 14, 2024 at 11:29 PM -
ChapmanF replied to the thread Confusion on 2012 used Prius C three Master Cylinder break replacement.
The whirring is the normal sound of a pump that makes up your braking pressure. The not-normal part is the pump having to run so often;...
Jun 14, 2024 at 11:26 PM -
462disco replied to the thread Low idle for a second or two upon startup?.
Did it myself. Very meticulous with everything- I’ll drive it another few hundred miles and recheck if the problem persists.
Jun 14, 2024 at 11:19 PM -
Mendel Leisk replied to the thread HV fan preset overriding.
There’s an assumption, that Toyota’s programming is not optimal?
Jun 14, 2024 at 10:41 PM -
Grit liked ASRDogman's post in the thread All the business!!.
13June2024[ATTACH]
Jun 14, 2024 at 10:31 PM -
Hammersmith replied to the thread Interior Noise Level.
Two simple ways. 1. Look for either the words Lamisafe or Temperlite on the outside of the window glass just above the door handle(with...
Jun 14, 2024 at 10:24 PM -
Prius RT liked bisco's post in the thread P3020 after battery work- Mod 10 service plug disconnect?.
see post #8 here: how-can-i-know-if-the-hv-battery-is-original.175439
Jun 14, 2024 at 10:11 PM -
Will B replied to the thread Interior Noise Level.
@Hammersmith : happy to check on my PPPXP, but not sure what to look for. Is there some text or a mark somewhere? Will
Jun 14, 2024 at 10:10 PM
