Recent Activity
Activity stream for all registered members at PriusChat.
BiomedO1 replied to the thread Multiple Dash Lights no codes on OBD.
From the symptoms alone, you've got at least one or morel bad batteries in your traction pack and/or the pack isn't recharging as it...
Jun 1, 2024 at 2:01 PM -
jonasetb liked phoenixgreg's post in the thread Dynamat 2.0.
Finally did the wheelwells. Yet more noise reduction at highway speeds: Prius sound proofing | Page 2 | PriusChat
Jun 1, 2024 at 1:56 PM -
Mendel Leisk liked R_W's post in the thread Coil Bolt?.
@Mendel Leisk: Mine looks like yours, except mine had a light coating of dirty oil and I didn't get too deep into cleaning around the...
Jun 1, 2024 at 1:52 PM -
Mendel Leisk liked rjparker's post in the thread Compression PSI in 2010?.
No I mean egr leaking flow at idle, low rpm’s or startup when the egr valve is closed. Which is the most likely egr cause of misfires....
Jun 1, 2024 at 1:51 PM -
G0LDM@N replied to the thread Can someone please explain to me what exactly is going on.
I can't really afford it I had a serious accident almost 3 years ago and even though I'm not at fault it's drastically increasing my...
Tombukt2 replied to the thread Lots of Codes Being Thrown - Primary U0293.
Yeah I don't know how that works when the dealer installs a new Toyota battery for you I don't guess you get a $1,300 discount and you...
Jun 1, 2024 at 1:50 PM -
bisco liked Its34below's post in the thread Canbus decoder setting off DTCs FIX.
[ATTACH] [ATTACH] [ATTACH] [ATTACH] [ATTACH] [ATTACH] [ATTACH] [ATTACH]
bisco replied to the thread Canbus decoder setting off DTCs FIX.
great write up, well done!
bisco replied to the thread I gotta say, I'm gonna keep it..
damned with faint praise
Jun 1, 2024 at 1:48 PM -
bisco replied to the thread Tackle it! Aftermarket brake caliper scratched rims.
make, model and year?
Jun 1, 2024 at 1:46 PM -
bisco replied to the thread Multiple Dash Lights no codes on OBD.
see here: autel-maxi-ap200-go-buy-this.232861
Jun 1, 2024 at 1:44 PM -
you need a prius aware scanner
Jun 1, 2024 at 1:42 PM -
bisco replied to the thread Hybrid Battery Reconditioning 2009 Prius.
there are some very successful reconditioning threads here, if you want to take the time to read them.
Jun 1, 2024 at 1:41 PM -
bisco replied to the thread The New Cadillac Optiq.
ouch! copying hyundai nomenclature and toyota maw, worst of both worlds
Jun 1, 2024 at 1:37 PM
