Recent Activity
Activity stream for all registered members at PriusChat.
AzusaPrius replied to the thread Project Lithium Soother Test.
@mudder I hope this will be the last time I will interact with you, clearly you have bad intentions and are not truthful in your...
Jun 15, 2024 at 11:45 PM -
bionicbadger replied to the thread Latest recall - sales stop!.
Production hasn't restarted yet, and the fix isn't rolled out to dealers anywhere yet (including in Japan, which would be first)
Jun 15, 2024 at 11:29 PM -
Dave Jeffries posted a new thread.
P1121 replaced pump still get the code
Last August I bought a Genuine Toyota Coolant Control Valve 16670-21010. I installed the valve and reset the codes. That lasted for...
Forum: Gen 2 Prius Technical Discussion
Jun 15, 2024 at 11:13 PM -
Tombukt2 replied to the thread EMERGENCY - son stranded - all lights, RTOD, flaky.
I'm banking it's the battery and it has an isolation fault many rebuilt batteries that I've dealt with have these in short order That's...
Jun 15, 2024 at 11:06 PM -
mudder replied to the thread Project Lithium Soother Test.
1: I understand you didn't '@' me on this one, but I'm still responding. 2: I agree, you are certainly allowed to post in your own...
Jun 15, 2024 at 11:05 PM -
Tombukt2 replied to the thread break into gen2 Prius?.
I can't get the airbags in my generation too You've got to get a screwdriver in there or something and really pry out on that window...
mudder posted a new thread.
Project Lithium's "Signal Soother" is Ill-Conceived and DANGEROUS!
<Placeholder> Moderators: Per @AzusaPrius' request, please move all posts including and after #67 in this thread into this thread. I...
Forum: Gen 3 Prius Accessories and Modifications
Jun 15, 2024 at 11:04 PM -
DanielR replied to the thread EV-Peak CQ3 Charger - D.Peak Settings.
If your cycle reaches a CAPA or charging capacity, it will stop with that cycle. What I do is set the charge capacity to 8,000mAh and...
Jun 15, 2024 at 10:52 PM -
DanielR replied to the thread High delta SOC and other symptoms.
Was there ever a resolution here for OP? I’m having a somewhat similar issue and would like a place to start. I have a mini-VCI and...
Jun 15, 2024 at 10:50 PM -
Andy Pants replied to the thread Gen 6 Prius engine will be a “game changer,” achieve a 53% thermal efficiency.
So let me get this straight, they are making the already "too small for Americans" Prius even smaller?! Wth are they thinking??? The gen...
Jun 15, 2024 at 10:39 PM -
ChapmanF replied to the thread Project Lithium Soother Test.
Haven't seen it yet, but it might be worth a try.
Jun 15, 2024 at 10:38 PM
