Recent Activity
Activity stream for all registered members at PriusChat.
N88GUM liked brandon's post in the thread Downloadable Toyota Prius Repair Manual.
Alright, time to get to the bottom of this. <div class='quotetop'>QUOTE(hobbit @ Oct 15 2006, 09:54 PM) 333260</div> Agreed. The SSL...
Jun 2, 2024 at 5:11 PM -
rjparker attached a file to the thread I gotta say, I'm gonna keep it..
The secrets of the (forum) universe has been discovered! [ATTACH] The Big Bang theory is just a gen3 blowing a hole in the block.
Jun 2, 2024 at 5:06 PM -
N88GUM liked mr_guy_mann's post in the thread P3004 - High Voltage Power Resource Code.
Normally when you power up the car, the hybrid control ecu controls the three HV contactors (relays). One is for the pack (-), one is...
Jun 2, 2024 at 4:27 PM -
N88GUM replied to the thread P3004 after HV block replacement.
Make sure your power cables are properly tightened. Anything remotely not upto spec can cause the error. It's a highly tuned system so...
Jun 2, 2024 at 4:09 PM -
Fatmatt86 liked kutcht1's post in the thread Burning 3.9qts every 1000 miles.
Well, enjoy your new car!
Jun 2, 2024 at 4:04 PM -
Fatmatt86 liked theory816's post in the thread Burning 3.9qts every 1000 miles.
It went out with a bang. 330k miles is impressive.
Jun 2, 2024 at 4:03 PM -
Fatmatt86 liked rjparker's post in the thread Burning 3.9qts every 1000 miles.
I would say yes you are correct sir! [ATTACH] [ATTACH]
Fatmatt86 liked Leadfoot J. McCoalroller's post in the thread Burning 3.9qts every 1000 miles.
[ATTACH]
soft_r replied to the thread I gotta say, I'm gonna keep it..
Validation seeking for your purchase is narcissistic and only highlights your insecurities regarding your purchase. No one cares if you...
Jun 2, 2024 at 3:48 PM -
rjparker replied to the thread I gotta say, I'm gonna keep it..
They could sell five times the current US sales if Japan could get them over here.
Jun 2, 2024 at 3:42 PM -
mjoo liked ozmatt's post in the thread Blown Head gasket rebuild....@297k.
Yeah sorry i figured out soon after posting, gen2 (proper Prius) had a chain but gen3 changed for gears.. I removed the starter motor...
Jun 2, 2024 at 2:51 PM -
Mendel Leisk replied to the thread Upper control arm, lessons learned.
What was the cost of parts for this? Also, did you get a quote from Tesla to do the job, and if so, what was the additional cost, above...
Jun 2, 2024 at 2:42 PM -
R_W liked Tombukt2's post in the thread Coil Bolt?.
Probably not hurting anything even when the code is being thrown Just make sure that you generally keep your oil between the dots on the...
Mendel Leisk replied to the thread I gotta say, I'm gonna keep it..
Still, two threads, one for cons, one for pros? ;) 5th gen'rs seem a chauvinistic lot, the lack of spares, cracked rear trim pieces and...
Jun 2, 2024 at 2:35 PM -
Mendel Leisk replied to the thread Tackle it! Aftermarket brake caliper scratched rims.
One an' done?
Jun 2, 2024 at 2:34 PM
