Recent Activity
Activity stream for all registered members at PriusChat.
Tombukt2 replied to the thread EMERGENCY - son stranded - all lights, RTOD, flaky.
That's all the possibility maybe it's broken down and causing an electrical problem inside the tranny or it's been replaced with the...
Jun 17, 2024 at 8:23 PM -
Tombukt2 replied to the thread Roommate's Car - P0A09 - Inverter Replacement?.
Only purple wires I see are on the big plug that goes through the half round rubber grommet into the inside of the inverter that you...
Jun 17, 2024 at 8:21 PM -
DavidMM replied to the thread Engine starts and shuts off.
Noted and thanks.
Jun 17, 2024 at 8:19 PM -
Lui Baiguer liked Data Daedalus's post in the thread I Beat the EPA--Post 'em here.
[ATTACH] So, I’ve started to use Esso E5 Supreme Unleaded 99+ in the UK, the recently foisted upon us E10 fuel is horrible and really...
Jun 17, 2024 at 8:17 PM
bisco liked JeD1's post in the thread Prius Gen 2 code C1311 C1377 - solved.
This post worked again. 2024 June. Every two years, like clock work.
Jun 17, 2024 at 8:16 PM -
Lui Baiguer liked Yosarian's post in the thread I Beat the EPA--Post 'em here.
Old thread, but wth... Recently acquired: '05 w/ 220k miles, flat dead hybrid & 12 v. batteries when I loaded it up & dollied it home....
Jun 17, 2024 at 8:14 PM -
bisco replied to the thread 2016 Prius needs 12 v battery - how to sell car.
it's hard to sell a car without a test drive
agrigento replied to the thread Noise coming from engine compartment.
Thank you Tombukt2 and mr_guy_mann. I think you are both on the money. I was referring to the wheel speed sensors. I was explained that...
Jun 17, 2024 at 8:13 PM -
bisco replied to the thread 2010 Prius problem with shudder.
do a head gasket check
Jun 17, 2024 at 8:10 PM -
bwilson4web replied to the thread Gen 6 Prius engine will be a “game changer,” achieve a 53% thermal efficiency.
EV range is a new skill which is why this will be broken into new and my 5 year old Tesla for charging and range: New EPA specs 25...
Jun 17, 2024 at 8:07 PM -
ironandsteel replied to the thread EMERGENCY - son stranded - all lights, RTOD, flaky.
Maybe I should check fluid level in the tranny? Or replace it and filter? 200k on the car.
Jun 17, 2024 at 8:01 PM
