Recent Activity
Activity stream for all registered members at PriusChat.
Car0751 replied to the thread Prius 2007 hybrid need help.
What about the red triangle sign is it okay to drive with it how do I fix that?
Jun 1, 2024 at 12:24 PM -
R_W liked Mendel Leisk's post in the thread Coil Bolt?.
Ours, for comparison.
Jun 1, 2024 at 12:22 PM -
R_W replied to the thread Coil Bolt?.
@Mendel Leisk: Mine looks like yours, except mine had a light coating of dirty oil and I didn't get too deep into cleaning around the...
fotomoto replied to the thread No Ready Mode.
First step: check 12v battery.
Jun 1, 2024 at 12:17 PM -
Mendel Leisk attached a file to the thread Coil Bolt?.
Jun 1, 2024 at 12:15 PM -
thetruth127 posted a new thread.
No Ready Mode
Would appreciate your troubleshooting procedures:
Forum: Prius v Care, Maintenance and Troubleshooting
Jun 1, 2024 at 12:08 PM -
Seymour1 replied to the thread help with battery temp sensors.
I decided to drop the sensor into the hole in the sheet metal. Gravity might keep it there. I could find no way to lock it into place.
Jun 1, 2024 at 12:07 PM -
PriusCamper liked Brian1954's post in the thread Code P0A94 & P0A7A.
The trouble codes point to a possible problem with the inverter. Toyota has an extended warranty for the inverter. Do NOT clear the...
Jun 1, 2024 at 11:58 AM -
rjparker replied to the thread Just need to vent....
A movie to watch in your tv while it is raining The Long Long Trailer [MEDIA]
Jun 1, 2024 at 11:56 AM -
bwilson4web posted a new thread.
Getting a grin from new Twitter/X
I've never had any interest in Twitter/X but a feature new to me, "block <user>" has made if 'less bad.' It takes several visit but...
Forum: Fred's House of Pancakes
Jun 1, 2024 at 11:44 AM -
rjparker replied to the thread Compression PSI in 2010?.
No I mean egr leaking flow at idle, low rpm’s or startup when the egr valve is closed. Which is the most likely egr cause of misfires....
Jun 1, 2024 at 11:43 AM -
bwilson4web replied to the thread Oops? (positive effect of sulfur dioxide in marine air pollution).
I've always seen them but their persistence, how long they last, appears to change. I think high cirrus clouds are beautiful but...
Jun 1, 2024 at 11:20 AM -
Danno5060 replied to the thread What Would You Like To Tell Toyota?.
A Prius BEV version - with 300+ miles range. 15, or 17" wheel trim options. Stop forcing customers to have to replace tires when we hit...
Jun 1, 2024 at 11:19 AM -
tochatihu replied to the thread Oops? (positive effect of sulfur dioxide in marine air pollution).
Whether contrails appear or not in general is controlled by humidity at flight level. Sometimes you see 'em and sometimes you don't.
Jun 1, 2024 at 11:14 AM -
Danno5060 liked douglasjre's post in the thread What Would You Like To Tell Toyota?.
Double the power of the AC, the engine, elec motors, and battery pack. Go 1200volt, and triple elec range
Jun 1, 2024 at 11:11 AM
