Recent Activity
Activity stream for all registered members at PriusChat.
ChapmanF replied to the thread Suitable substitutes for the Toyota ATF-WS transmission or transaxle fluid?.
"wasn't in contact with it before Gen 3" is clearly false, given that Toyota published a paper explaining the change from not-in-contact...
Jun 15, 2024 at 3:41 PM -
rjparker replied to the thread 12 V battery dead after one hour with clicking noise in engine compartment.
New battery after a passing parasitic draw test.
Jun 15, 2024 at 3:39 PM -
Seymour1 attached a file to the thread 2010-2015 Inverter Pump Replacement.
My 2010 Prius reports a P0A93 and a P0C73, both telling me that the pump is bad. Also, there is no turbulence in the inverter pump tank....
Jun 15, 2024 at 3:31 PM
Eddie25 replied to the thread HV fan preset overriding.
I used Hybrid Assistant fan control for a while after constantly seeing my battery at 130F and the fan on 2. I don't use an android...
Jun 15, 2024 at 3:22 PM -
Abarnabe liked douglasjre's post in the thread Suitable substitutes for the Toyota ATF-WS transmission or transaxle fluid?.
Maxlife LV works well. Done many CVT fluid changes in Prius over many years on more than 2 dozen pri and no failures. Can't from wrong...
Jun 15, 2024 at 3:18 PM -
Abarnabe attached a file to the thread Suitable substitutes for the Toyota ATF-WS transmission or transaxle fluid?.
it is available, but at the price of 20 usd per liter + 20 usd shipping
Jun 15, 2024 at 3:14 PM
PriusCamper liked Mendel Leisk's post in the thread From Near Death to Living in a Prius.
Subscribed. You look nothing like your avatar lol.
Jun 15, 2024 at 3:14 PM -
PriusCamper replied to the thread My Project Lithium Battery Caught Fire.
Hi Mudder, I posted asking for help on your LiBCM tech support thread on InsightCentral day before yesterday because software update for...
Jun 15, 2024 at 3:05 PM -
Eddie25 replied to the thread Advice regarding correct MAP sensor values.
Personally I'd want to see a graph of the short term fuel trim numbers while driving (as they relate to RPM). What does the MAP read...
Jun 15, 2024 at 2:51 PM -
Tombukt2 replied to the thread EMERGENCY - son stranded - all lights, RTOD, flaky.
I own AP200 also as well as Toyota TIS software from the dealer Don't ask but it doesn't matter they both work extremely well so did the...
Jun 15, 2024 at 2:49 PM -
Tombukt2 replied to the thread throttle body replacement re-learn procedure.
I didn't think we could really do anything to our throttle bodies but they're so reliable they rarely get touched If they mess up in the...
Jun 15, 2024 at 2:47 PM -
Tombukt2 replied to the thread 2004 Prius: Troubleshooting Cruise Control.
First I personally would probably get the CM monitor or the display that you're talking about fixed It's a standard problem makes the...
Jun 15, 2024 at 2:42 PM -
Tombukt2 liked WaylonWillie's post in the thread 2004 Prius: Troubleshooting Cruise Control.
Hi Everyone: 2004 Prius with 175k miles. My cruise control is very difficult to turn on (pushing the button on the stem works only...
Jun 15, 2024 at 2:40 PM
