please list your cell phone that works in the 2010 prius
Discussion in 'Gen 3 Prius Audio and Electronics' started by syncmaster, Aug 8, 2009.
  1. Yankeefan
    Yankeefan Junior Member
    26
    Salt Lake City, UT
    2026 Prius
    Iphone 3G. No problems.
  2. Jim Calvert
    Jim Calvert New Member
    255
    28
    Worthington, Ohio
    The Samsung SCH-u410 cellphone works fine. No connection problems at all. I keep it in the glovebox and only take it out for recharging. Handsfree is great!
  3. anatooli
    anatooli New Member
    Finland
    Hi!
    You can try this:
    - if you have Prius 2010 audio with navigation
    - clear Pairings from your Prius what you did before
    - if your friend has iPhone, let him pair iPhone to Prius using only bluetooth music player. (not handsfree)
    - after that, shutt iPhone bluetooth (but leave bluetooth audio pairing to prius)
    - pair your Nokia N95 to prius (like handsfree, not bluetooth audio)
    - start Prius and turn Prius off once
    - N95 stays connected (I hope) if you press manually "connect phone" and then select N95
    Tell me if that helped... but every time, you start your Prius, you have to connect your phone manually.
    Looks like that audio model has problems with symbian 60 based Nokia phones...
  4. anatooli
    anatooli New Member
    Finland
    Hi!
    If your handsfree is ok, can you send all your contacts from E65 to Prius?
    How about the bluetooth streaming in audio, does it work?
    anatooli
  5. NovaStu
    NovaStu New Member
    102
    Fairfax, VA
    I'm happy with my Sprint Sanyo KatanaLX. Easy to transfer the phone book, reliably handshakes with the car, clarity is acceptable+.
    Stu
  6. garygid
    garygid Senior Member - Blizzard Pearl
    379
    Orange County, CA
    The Samsung SCH-u430 for Verizon works well,
    but it appears that a few contacts did not transfer to the Prius.
    Almost all transfered OK, ... I wonder why.
  7. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Motorola v3xx
  8. Vancouver
    Vancouver New Member
    42
    Vancouver
    I've been able to pair the Nokia E65 to make and receive calls. I'm able to transfer contacts - but only by sending them from the phone, not by the Toyota feature to pull them. I also can't seem to get audio streaming to work at all. I don't think the E65 has the right type of bluetooth connection to do that. (It is mono bluetooth.)
  9. grantb3
    grantb3 Junior Member
    60
    Orange County, CA
    LG Voyager. Pairing was a tad odd, but not too difficult.
  10. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
    My M800 Samsung Intinct works very well in my Prius III.
    Tony Renier
  11. acburdett
    acburdett New Member
    Verizon Blackberry Storm 9530
  12. pdv
    pdv New Member
    Belgium
    Very similar problem here.
    N95 8Gb, pairs fine, then stays connected for that ride, and that ride only.
    Automatic connection set on.
    But on next ride: connects + disconnects immediately after.
    Is this fixable ?
    Hate to have to go through the pairing every time I get into the car.
    Any help is Appreciated.
  13. windstrings
    6,280
    378
    Central Texas
    My Motorola Droid links perfect for phone audio, but multimedia will not link so far..... either I'm doing something wrong, or I don't have that feature on my early release GenIII, or my phone is not playing well.
    There is supposed to be a firmware release for my phone Dec11.. hopefully that will fix it.
  14. ridoanna
    ridoanna Junior Member
    Sacramento
    My Samsing T349 will not work. I want to purchase a HTC Touch Viva, but I am not sure it will work. I left my Priius manual at work. I believe it said you nee protocols HFP, OPP and PBAB. The Samsung has HFP and OPP and still will not pair up. I have seen here that the HTC Touch Pro2 and the Touch Diamond work. Does anyone know it the HTC Touch Viva will work? Thanks.
  15. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    Nokia 6600 Slide and Blackberry Pearl 8100.
    I am mainly using the Nokia and unfortunately the transfer of the phone numbers to the Prius address book does not work. I needed to insert a few by hand....
  16. Bike-a-man
    Bike-a-man New Member
    Old Saybrook,CT
    LG vx-8550 Chocolate Works fine
  17. Sangye Menla
    Sangye Menla Junior Member
    Seattle
    Samsung SPH M300 (works fine)
  18. ridoanna
    Sacramento
    I have narrowed my choice in cell phones to a HTC Touch Viva or a Nokia 5530. Has anyone tried these phones in the Prius? The Toyota site is very incomplete. It shows mostly what will not work and very little of what will work. I read about the parameters that are required in the Pruis manual. My Samsung T349 had 3 of the protocols listed and still will not work. Maybe I will go to a cell phone store and have them come out to my car and try to pair it up. I am looking for an unlocked phone. Lots of possibilities on Amazon but I just don't know what will work.
  19. equake
    equake Member
    155
    Los Angeles
    Verizon Motorola Droid works with both BT Phone and Audio Streaming. Contacts do not transfer over properly but a workaround is using the Bluetooth File Transfer applet from the Android Marketplace to transfer a vCard *.vcf exported file.
    The USB does not seem interface for Audio but does charge the phone.
  20. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    Nokia 6230
    HTC Diamond
