Well, I'm off to the upholstery shop to inquire about seat reshaping
Discussion in 'Gen 2 Prius Main Forum' started by cycledrum, Oct 18, 2009.
  1. CharlesJ
    CharlesJ Member
    467
    29
    Monterey
    Did you by chance check to see if a 2010 Prius seat would fit in there? While I am not even near your height, I don't have a wide butt either and the seat is not comfortable for long/er trips;):D
    I was wondering about the 2010 seats and this is the right time and place to ask:D
    I popped my seats out to fit the seat covers and it is not bad at all to pull it out.
  2. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    No, a 2010 seat will not fit - it's a different frame, mount pattern and electrical is different.
  3. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Oh boy, getting good upholstery service is not happening yet.
    I checked the seat into the closest upholstery shop. They have an A rating with the BBB. I'm not sure why ...
    I left it with them first thing Tuesday morning. I called day later to ask a simple question. The guy said he might get to working on it this afternoon.
    I stopped by late afternoon while in between running a work errand. Said, so where's that seat at? We walk back and shows me the seat laying on the bare shop floor. I say, gee, couldn't you lay it on something?
    I couldn't bring the seat home right then and there, but I'll be retrieving it first thing tomorrow morning. I made it quite clear that it is a custom mounted seat that I've put a lot of work into. Lay it on the shop floor and I'm no longer a customer.
    I called the 2 Toyota dealers and neither of them refer to the shop I've dealt with so far - King Kovers in Fremont.
    Hayward Toyota uses King Kovers in Hayward which is not affiliated with the Fremont shop.
    Sigh. I could learn how to uncover the seat fabric and do the work myself. I might get better results that way.
  4. guru_del
    guru_del New Member
    33
    Lake Elsinore, Ca.
    i have had similar experiences with radio install shops, which led me to just learn to do it. Now i have no one to blame but me. Sometimes crappy service is just the kick in the shorts we need to learn a new skill.
    food for thought. (mmm thoughts of food...)
  5. CharlesJ
    CharlesJ Member
    467
    29
    Monterey
    Thanks. There went my hope for a better seat.:eek:
  6. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    There are shops out there that would be more than happy to install a Recaro seat, usually the Specialist M model in a 2004 -09 Prius, but it'll set you back about $1,700 for 1 seat, mounted and plugged in.
    Maybe that's not so bad as Toyota charges over $2,500 for 1 Prius driver's replacement seat. Crazy. I was quoted a price of $3k for a 2008 Corolla driver's seat from Toyota, last week.
  7. djg12
    djg12 Junior Member
    N.H.
    I read this thread with great interest. My '08 seat bothered me 6 months ago then it seemed ok. It has now come back with a vengeance to bother me. The same 'pain spots' you have described. The side bolsters just 'get 'cha'. I am 5'1'' at best and even then the seat is horrid.
    I owned a 2004 RAV4 that I sold, one of the reasons was the seat was terrible, for the same exact reason. Had I known they took the seat out of their old RAV to put it in the Prius I would not have purchased this vehicle. Toyota is missing the boat on seat design.
    Even with the prospect of a financial loss I am seriously considering getting rid of the Prius and will never buy Toyota again.
  8. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Well, since you're 5'1" you probably have extra headroom to sit on a seat cushion.
    Here's my suggestion, seriously ......
    You could cut a template that follows the contour of the flat portion of seat bottom (you know, it curves outward towards front of seat).
    In that section, you could put something like 3/4" of firm foam (cover it though) shaped like the template. When you sit on the foam, those raised sides won't press in as much. Although I haven't tried this, but with only a 1/4" of foam, it seems that it would help.
    And with Toyota, basically the bigger cars have the bigger seats. Camry and up is where things get nice. Corollas and down, not so much.
    But, the 2010 Pri is a small-midsize car with midsize seats, so Toyota listened 'bigtime'.
  9. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Just to follow up, I didn't do nor did I have any seat shaping or shaving done at all.
    After partially removing the bottom fabric it appeared you really cannot shave down the bottom flat portion. There seems to be hook wires in the foam that attach to hog rings on the fabric. If foam was shaved, seems one would then be sitting on those hooks, not good.
    Any shaving of sides would require re-sewing the cover so fabric is not saggy. More money out of pocket for little gain. I just put the seat back together, popped it in the car, covered it, that's it.
    I learned some about seat disassembly in case I get into the next big mod.
  10. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Who needs an upholstery shop. Time to deal with this devil of a seat bottom on my own terms.
    I wonder if any dremel cutting tools will shave foam well, hmmmmm
  11. guru_del
    guru_del New Member
    33
    Lake Elsinore, Ca.
    best tool i have ever used for shaving foam is an electric turkey knife. The kind with two serrated blades. Works wonders.
  12. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Thanks! I bought a $50 Cuisinart electric knife last weekend. It cut my sample foam piece well.
    I tried my dremel with high-speed cutting bit and it shaves foam. It makes a lot of foam dust so maybe I'll just use it for the hard to reach places.
  13. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Relaxing those annoying raised sides on the seat bottom. I'll be cuttin' & sittin' a lot this weekend. I might shave the flat bottom portion depending on how the dremel works on this foam. There seems to be room to remove roughly 1/2" foam on flat portion and still be able to attach the OEM cover.
    I know it might be a pain to have the bottom fabric modified. Maybe I'll just put a generic cover over the seat back and bottom and leave it at that. I'll know when I get to that point.
  14. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    IMO, if you leave the OEM bottom cover unmodified and just hog ring or cable tie it back on as taut as you can, that will look better than putting a generic seat cover on.
    I think that even a slightly baggy OEM bottom cover will look better than generic seat covers.
  15. jessealan
    jessealan New Member
    Idaho
    I bought something called sacro wedge, it is a higher end seat wedge. Very good firm memory foam. Corrects posture and keeps strain off my low back. paid 64 on ebay with free shipping. money well spent.
  16. jessealan
    Idaho
    sorry it is called sacro ease wedge made may mcarty sacro ease.
  17. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    One Saturday using electric knife and a dremel rotary tool
    To make this (not quite final shape, but close)
    Sunday it's back together again
    I was able to take over 1/4" off the flat portion by bending the foam to get in with electric knife.
  18. guru_del
    guru_del New Member
    33
    Lake Elsinore, Ca.
    if you cant find a suitable retail solution, do it yourself. Great work.
    Any better?
