Need Help Disassembling Driver's Seat
Discussion in 'Gen 2 Prius Accessories & Modifications' started by cycledrum, Nov 15, 2009.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    That one your just going to have to break. I never got that one out.
    Why are you needing to remove it? If your installing seat covers just wedge the cover down the side. Thats what I did when I installed my seat covers.
  3. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I want to remove the seat cushion fabric, get to the seat cushion (the foam) to consider shaving / shaping it.
    Are you serious about needing to break that claw to remove left side trim piece?
  4. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Yes unless someone else here knows how to actually remove it.
  5. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I got the piece off without breaking the claw. The diagram helped.
    I used an L shaped flat tip screwdriver held by pliers to wedge into the crevice. The claw is totally hidden from view. That was tough.
  6. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Intentionally deleted.
  7. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I put the seat back together and installed it back in the car. No further modifications, too risky.
    In my opinion, the next better mod would be to get a good 03 - 08 Corolla seat, move the airbag/wiring from a Prius seat over to it, mount Prius feet on it maybe on extendmyseat brackets or with rail extenders.
    Once you get the seat down low (for a tall person), then you've got more options for seat cushions.
    I might take up such a project next year.
