MPG guage updated?
Discussion in 'Gen 3 Prius Fuel Economy' started by alfon, Nov 1, 2009.
  1. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Does anyone out there have confirmed information that the newly manufactured Prius's have there MPG guage updated to reflect a more accurate reading.
    Our Prius was the first to come off the line back in May 2009, and currently approaching the 14,000 mile mark.
    The guage has been consistenly off by 2-3 MPG from the beginining.
    I believe some of the newly manufactured Prius's have a more accurate reading than earlier ones.
    Can anyone out there with a newly manufactured prius confirm this.
    alfon
  2. Yankeefan
    Yankeefan Captain Planet
    26
    Charleston, SC
    Mine was built in Sept. My gauge was dead on when I did my calculations on a recent 720 mile road trip. I can't confirm nor deny, just saying what I found.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Very interesting. I wonder if they patched/fixed their software. I will have to ask my dealer when I bring it in for the OCI.
    Have you been able to check your speed readout say to a radar gun?
  4. hotbrass
    hotbrass New Member
    312
    35
    Cowtown
    Mine was made in Aug and it is 2-4 mph off. I checked with ScanGuage and two different GPS systems.
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    MPH or MPG? Mine is about 1 MPH off where as the MPG is about 5% or 4 MPG.
  6. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    MPH is off about 1 mph at 55 mph. And the only time I have checked gas mileage against the HSI I was off just a hair at 1.1 mpg. That was at the first click of the nozzle BTW.
    Manufactured May of 09.
  7. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    The speedometer is not relevant to the consumption display. The speedometer reading that is displayed is always going to be fast because of the UN regulation on speedometers. The ODB knows the true speed of the car, a ScanGauge will display the actual speed.
    The consumption display uses fuel flow to the injectors and distance traveled, not speed. The consumption display is also off but not because of any regulation, it's off because Toyota marketing decided it could fool the customers into thinking the car actually got better mileage than it does. They didn't think some owners were actually smart enough to figure out what they had done fairly quickly.
    If it has been fixed on later cars that's very good but it's most likely as close as they will ever come to admitting that they made an error in judgment. I will be pleasantly surprised (very surprised) if they call in the earlier cars and offer to fix the problem.
  8. deltron3030
    deltron3030 New Member
    437
    64
    Lakewood, CA
    newb question...how do i figure out the manufacture date of my car?
  9. tumbleweed
    4,067
    692
    Eastern Oregon
    There is a sticker inside the driver's door frame.
  10. chiguy
    chiguy New Member
    25
    Champaign/Urbana
    So what would I ask for if I were to go to the dealer? Firmware updates?
  11. hotbrass
    hotbrass New Member
    312
    35
    Cowtown
    Is there a TSB on MPG/ODO deviation. I assume they would not jack with MPH.
    ScanGauge is close enough for me. I also do the calculation every time I fill up. None of the three match or even come close all the time. Mostly the SG and calculation are the closest.
  12. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    It's not "broke", they aren't going to "fix" it, it works exactly as intended, and I bet 95% of owners aren't smart enough to know any better.
  13. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    You hit the nail on the head with that statement. :p
  14. hotbrass
    hotbrass New Member
    312
    35
    Cowtown
    Of course its not broke. Its just wrong. If the gas gauge was calibrated incorrectly, it would not be broken, just wrong. I bet they would fix that, well, maybe not.
    In software, it is called an "undocumented feature."
  15. raysprius
    raysprius New Member
    St Petersburg, FL
    July '09 manufacture date and MPG gauge consistently 1 - 3 mpg high relative to fill-up calculations. Comments on Fuelly.com indicate this is common. Calculations and MPG gauge should use the same distance data so that does not explain the difference. Measuring accurate fuel flow is an inexact science which requires fuel specific gravity, temperature, flow correction adjustments, etc., etc., etc. I imagine the flow meters used on cars are cheap and inherently inacurate (my BMW's MPG gauge is also 1 - 3 mpg high). While the gauges are not accurate they are useful as relative indicators of fuel usage which is probably all they were intended for.
  16. codybigdog123
    codybigdog123 Got Mad and Left in a Tizzy
    239
    29
    Chicago, Il
    I now have over 2,700 miles on my GenIII. I fill up once a week, every week since taking delivery in August. Every week the difference between the measured and computer generated MPG is 2-3 MPG, with the measured value always being lower, but always higher than the combined EPA number of 50 MPG.
    I now have a high degree of confidence that when the diplay says I'm getting 54 MPG, I'm probably getting closer to 51 or 52 MPG. As stated above, there are errors associated with both the measured and displayed MPG figures. So what? Is this really a big deal? :confused:
  17. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    That has been my experience with my G3, IV. I downloaded (off this site) an Excel chart someone made. With 6600 miles, my actual is consistently 2.1 mpg lower than the indicated. With that knowledge, I can live with it. Sure, I wish it were perfectly accurate, but being consistent is better than being inconsistent. Few things in life are perfect. That is especially true with automobiles; media reports; politicians; and etc.
  18. bkilian
    bkilian New Member
    Renton, WA
    It may be as designed, but it is misleading, especially since one of the selling features of the vehicle is good fuel consumption.
    Hyundai had a recall and had to offer longer warranties to customers because they misrepresented the displacement on their Sonata engines (and not by much either).
    If it was "within 5%" but varied from car to car and tank to tank, sometimes low, sometimes high, it might be ok, but it is consistently 5% high, and if this was intended, makes it a purposeful misrepresentation.
