New Prius in 2007?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by thorn, Jun 29, 2005.
  1. thorn
    thorn Member
    101
    Maryland
    When is Toyota going to come out with a new Prius? They say 2007 in this article:
    http://www.autoweek.com/news.cms?newsId=102675
  2. Danny
    Danny Admin/Founder
    7,093
    2,118
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    I think for the purpose of this article they were referring to the fact that in 2007 Toyota will have out the Camry, GS, RX, and the Prius all in Hybrid forms. However, 2007 would be the normal model year for the Prius to get an overhaul, following Toyota's prior schedule.
  3. Tideland Prius
    16,505
    isn't Toyota's cycle 5 years, not 4? I mean, the old Prius has been around for 6 years (Type-10 98-00, update (Type-11) 01-03).
  4. neight
    neight New Member
    Greenbelt, MD
    98-00 and 01-03 are both 3-year cycles, by my count... that would indicate that indeed we will be due for a new Prius model in 07.
  5. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    <div class='quotetop'>QUOTE(neight\";p=\"102855)</div>
    From the pictures I've seen the 00 to 01 change was more on the order of a trim change. Perhaps like the difference between an 04 and 05 Camry (check out the taillights).
  6. Panther87
    Panther87 Junior Member
    S.E. South Dakota
    I don't know what Toyota can really do to dramticly change the car without losing it's main selling feature, gas milage. Toyota has added options every year it seems. Also they increased the size of the car a little this year ( 05 ) I think.
  7. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    The 2005 Prius is no larger than the 2004. It's 04 and 05 are exactly same, actually, except the rear wiper is standard and the option packages (not options) differ.
    I can think of a number of things they could do:
    1) Add a super/turbocharger (possibly as an option)
    2) Add additional noise reduction (they are doing a bit of this in the 2006).
    3) Update the NAV system to add traffic data integration.
    4) Larger capacity and/or lighter weight battery (using a battery with higher energy density).
    5) Larger electric motor/2nd electric motor for back wheels (a 2nd one is unlikely, IMO, tho')
    6) Improved engine programming
    7) Cold air intake
    There's probably a bunch more too, and they probably would not have any gas mileage penalties since a newer design will improve upon gas mileage as well. Some of the improvement may be given up due to additional weight of new options, or there may be ways to shave weight off the existing design to compensate for additional weight. It's a complex optimization problem like most engineering tasks and there's always lots of options on what to do.
  8. Sufferin' Prius Envy
    3,998
    <div class='quotetop'>QUOTE(ryogajyc\";p=\"102942)</div>
    Well . . . not exactly the same . . .
    Two buttons have been installed to hold up the headliner in the ‘05 Prius that aren’t in the ‘04.
    There may be other changes, but I think that one in the most critical. :wink:
  9. Tideland Prius
    16,505
    Err no. It's more like Gen 1 and Gen 1.5. 01-03 is an update (bumpers, rear lights, lighter/more powerful battery). Liek jfschultz said, e.g. 02-04 Camry is the gen 5 then 05 would be the updated one or gen 5.5 so to speak.
  10. Frank Hudon
    Frank Hudon Senior Member
    4,147
    I still think the Prius will eventually be dropped. Once the Corolla is available with HSD the reason for the Pruis really isn't there anymore. The Prius is/was mainly a POC design and once that the hybrid system is in the main models why keep putting out a one single model line. Corolla Camray Hylander all available with ICE or Hybrid, Prius only with hybrid to me makes little sense. Just my 2 cents.
  11. NuShrike
    NuShrike Active Member
    1,378
    Unless they keep the Prius around like Honda's NSX, the poor Prelude too, and the Si line as a demonstration of all the latest technology from the company.
    Not something to make money from, but an established line that long-term market tests certain techs.
  12. Fredatgolf
    Fredatgolf New Member
    339
    Pinehurst
    <div class='quotetop'>QUOTE(Frank Hudon\";p=\"103051)</div>
    I disagree about the Prius being dropped. Prius is an entirely different car from the Corolla. In order to drop the Prius, they would have to completely redesign the Corolla. That is what the Civic is doing in '06 if you have checked out the posted pictures in this group.
  13. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    I sure hope they don't drop the Prius. I would never be interested in the other Toyota's with or without hybrid design.
  14. Frank Hudon
    4,147
    <div class='quotetop'>QUOTE(Fredatgolf\";p=\"103064)</div>
    [/b][/quote]
    the Civic is still a Civic. Prius is only one model. Toyota has dropped model's before and with HSD in most models by 2006-8 why have one model line with no ICE option.
  15. Danny
    Danny Admin/Founder
    7,093
    2,118
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Well, by 2008 the Prius will still have a freakish following. I mean, look at the growth PriusChat has seen in the last 6 months.
    But, this is the company that got rid of the Supra...
  16. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    I doubt that the Prius would be dropped. It has become a halo car for Toyota. The Prius will likely still be the forerunner for new Toyota technology - maybe the first production fuel cell hybrid in the future? Who knows.
  17. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I think it is a typo. It should be Toyota Highlander hybrid instead Prius. 400h and HLH were launched a few months away.
    Dennis
  18. HSD
    HSD New Member
    <div class='quotetop'>QUOTE(Wolfman\";p=\"103315)</div>
    Hello to everyone! I am a Prius enthusiast from Greece and a wannabe Prius owner!!! :wink: . I think that " Prius is a Live Revolution!!!
    Of course, there are many projects running in Japan, like Partner robots,Holographic Displays,Photonic Networks-(end of history for RF waves?), Silicon Cardibe Wafers, Self Parking and who knows what else...
    I think, that Prius is "the portal", for all these things to come... :wink:
  19. Godiva
    Godiva AmeriKan Citizen
    10,339
    I also do not think Toyota will be dropping the Prius. It has become the identity for hybrid much like "Kleenex" and "Xerox". It is the hybrid to which others are compared. It also has a majority of the market share, at least for now.
    I think Toyota will keep the Prius (and I think the popularity of the Prius will continue to grow and keep it strong) but I think Toyota will be using the Prius to introduce new concepts and technology. Then after a year or two whatever it is will be added to the rest of their hybrid line.
    Sorta like they started the HSD with the Prius and now it's part of the Highlander and Camry lines.
    I don't think Toyota is stupid enough to kill the golden goose when it is still a gosling.
  20. ChuX
    ChuX New Member
    66
    NYC
    Although the Corolla will be getting the HSD in the future, I think Toyota would use the Prius to push the mileage ceiling even higher such as by using carbon fiber to reduce the weight of the car and have any new concepts tested on the Prius first. In addition, I think the Prius would serve as the model with the latest technology at a reasonable price.
