How many leaf cars can you produce?
Discussion in 'Gen 3 Prius Main Forum' started by Tideland Prius, Oct 2, 2009.
  1. Tideland Prius
    16,549
    Ok for those that don't know, the maximum no. of leaf cars that the old Gen 2 can display is 4 cars. The most I ever got was 3½ leaf cars. (this is for the 5 min cons.)
    So you can imagine my surprise when I saw this (and I apologise for the poor quality)
    7 cars! That's 350Wh of elec. regenerated by braking. I'm wondering how much of an improvement Toyota has made on recovering the energy because I noticed it's much easier to top up the battery via braking which means less fuel is needed to burn to run the engine to recharge the battery during city driving. Mind you, these 7 cars were taken after descending one side of the Rocky Mountains. You can tell I just climbed the mountain because the average is reading 5.1L/100km (47mpg US)
    Here's another shot of the first part of the trip.
    5 cars this time.... and if you're wondering how that looked like in the 1 min. consumption screen....
    Stack 'em up!! 50mpg (4.7L/100km). This trip ended with 4.3L/100km (55mpg US)
  2. qbee42
    3,079
    With the Gen II, is the limit an actual system limit, or simply a display limit?
  3. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    Ummm...ride your brakes a lot do you???
  4. Tideland Prius
    16,549
    Not sure. Never took the Gen 2 across the Rockies. In the steep mtn back home, I'd take it from 2 bars to 8 bars and I've never seen 4 leaf cars.
    Well it's that or let the car roll down the side of the mountain range and max out the speed :D
  5. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    what the hell is a leaf car?
  6. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i got 5 cars on a trip thru the pass on the way to Leavenworth. it was like an 8% grade which i basically "coasted" down the hill for about 10 miles. dont think i touched the brakes more than once to slow down to go around a truck trailer sitting not so far off the side of the road.
    the part that sucked was that the cars stopped in about 4 minutes because that is how long it took to top off the battery. bummer
  7. Omni-TaG
    Omni-TaG New Member
    37
    I
    Wanna see some leaf-cars ?
    These little-green-leaf-cars where produced last july at "Les Éboulements" north of Québec City in the Laurentian Mountains.
    lol:)
  8. Tideland Prius
    16,549
    Umm, did you even see my photos?
    Nice!!! How did the 5 min. bar go?? That should look pretty impressive too! (Note that the 1 min. leaf cars are 30Wh and the 5 min. leaf cars are 50Wh)
  9. garygid
    garygid Senior Member - Blizzard Pearl
    379
    Orange County, CA
    So, does "getting a car" mean one has regenerated 30 (or 50) Wh in that 1 (or 5) minute(s)?
    How does one switch between the 1 and 5 minute display?
    The usable part of the Gen3 Prius' battery (the 40% from 40% full to 80% full) is about 500 Wh, I believe.
  10. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I think it's the DISP button on the touch tracer, just hold it down while on the screen showing the 1 or 5 min intervals and it'll switch between the 2 modes.
  11. Omni-TaG
    Omni-TaG New Member
    37
    I
    Hi Tideland
    I do not have pics of 5 min. time span. I recall that the battery was so "full", that the 8th graph-bar (on the little battery pictogram) took a certain time to go off.
    I'm shure that i was producing a huge amount of electricity that i could'nt store that day, due to battery limitations. Have i had two batterys that day i would have fill then up !
    @ Garygid
    Yes but understant that it is one and every single "leaf-car" pictogram that worth 30W/h for the 1 min. span and 50W/h for the 5 min. span.
    To swich from 1 to 5 min. span just push "disp" (steering right branch) button holding it for 3 seconds, it'll then switch from 1 to 5 and back.
  12. garygid
    379
    Orange County, CA
    OK, 3 sec press of Disp when on the 1 (5) sec display switches to 5 (1).
    Thanks!
    Every time I try to read the Owner's Manual, I fall asleep.
  13. Tideland Prius
    16,549
    Correct. That's only via regenerative braking only. It doesn't count any energy coming from the engine to recharge the battery. In the city, you want to minimise the no. of leaf cars (cause that means you're braking too often and not maintaining momentum). I was in the mountains, that's why I managed to recover that much.
    wow.. that's a lotta mountain driving.
  14. westerman
    westerman New Member
    Lafayette, IN
    After reading several forum posts I am still unclear on what the 'leaf car' actually means. Yes it clear that it means 50wh or 30wh (depending on the display). And that number can be related to the electricity I use at home. If I am correct then at a cost of $0.10 per kilowatt hour from the electric company it means each leaf car is "worth" a half of a penny or less. Or another way of looking at it is that each leaf car is like leaving one or two CF-lights on for an hour. So I can relate the leaf cars to home use. But how do they relate to car use? I.e., how many gallons of gasoline savings does each leaf car represent. I am sure that there are lots of variables but is there a rough SWAG? I think that each represents 1/100th of a gallon of gas but would like to hear from someone who actually knows. TIA!
  15. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    A typical plug-in Prius runs 250Wh/mile, so the single 50Wh leaf car means you can drive Prius in EV mode for 0.2 mile.
    Ken@Japan
  16. westerman
    Lafayette, IN
    0.2 miles per leaf car. 40-50 mpg. Means a leaf car is about 1/225th of a gallon. That is about 1/2 of my guess but given the inefficiencies of converting from gasoline to electric and back again the 1/225th number seems correct. Thanks for the information.
  17. hill
    8,794
    The other option would be to stay off the brake, push a tiny bit on the accelerater & hyper stealth down the steep grade in order to prohibit the ICE from spinning off extra regen that'd be created by riding the brake. You'd be doing over 100mph in no time ... er, I mean so I've heard ...
  18. going red baby!
    going red baby! still a n00b
    610
    96
    Los Angeles
    I somehow managed to get 6 leafs in 5 min. mode driving around L.A.! And when I noticed it I was on Mulholland Dr. and had just come UP the hill! And no, I don't ride my brakes when I drive. I had come up a nice windy road and was seeing how Red handles, so perhaps the braking into curves did it?
    Btw... definitely not a sports car. ;) I found the acceleration really lacking in responsiveness.
    Wondering if when you see something show up, is that the last 5 min? Or is the last column in progress and so you see it changing while you drive?
  19. 3PriusMike
    3,100
    2,419
    Silicon Valley
    When you see the far right column that is the last 5 minutes (or last 1 minute if you press and hold down the display button to toggle the mode).
    The "current" mpg is shown near the speedometer. In the Gen 1 and Gen 2 the current mpg value is shown on the far right on the display, but there is a deliniation as you move to the left where the "history" is shown.
    3PriusMike
  20. Tideland Prius
    16,549
    PWR Mode ;). I found that made the accelerator more responsive and you get more power now rather than letting the car "spool" up. When I was "carving" the back country roads, PWR mode made it felt like the accelerator was an on/off switch. It was also the time I wished I had the quicker steering of the Touring Package.
