How many remote access keys does a Prius come with?
Discussion in 'Gen 2 Prius Main Forum' started by odysseus, Dec 13, 2009.
  1. odysseus
    odysseus Junior Member
    61
    Austin, TX
    How many "keys" does a Prius with remote access keying come with? How much does a new remote access key cost? I understand that the key is supposed to come with a key number plate, and that the number on the plate is required to make duplicates of the key. If I'm buying a used Prius, should the dealer be able to give me the key number plate?
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    It's supposed to come with two key fobs.
  3. qbee42
    3,079
    The key number refers only to the mechanical key. Fobs cannot be duplicated.
  4. odysseus
    61
    Austin, TX
    Maybe not, but can't the car be programmed to work with another fob?
    Or put another way: if the used Prius comes with only 1 fob, I could never get another? What happens if you lose your fob?
  5. qbee42
    3,079
    Yes, you can add additional fobs to the Prius. Your lost fob can be removed so that it will no longer be recognized.
    You need to go to the dealer to program in a new SKS fob, and it must be a *new* fob. You cannot add a used SKS fob, so be careful with EBay.
    Dumb fobs can be added by the owner, and used SKS fobs can be added if used as a dumb fob.
    I only mentioned the key code comment to avoid any confusion. Some new owners think the key code will allow someone to program a new fob to work with their Prius, which is not correct.
  6. odysseus
    61
    Austin, TX
    What is a "dumb" fob? Is that a different level of privileges?
  7. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    A 'dumb' fob means that it can be used to start the car by inserting it into the slot. But no SKS functions will work and the lock and unlock buttons will not work.
  8. odysseus
    61
    Austin, TX
    Thanks. How much does a "smart" fob cost?
  9. firepa63
    1,761
    208
    Call several dealers in your area to get a quote on the fob and programming the car to accept the fob. The prices will probably vary, but you'll be in the area of a couple of hundred bucks.
  10. odysseus
    61
    Austin, TX
    That's an obscene amount of money for what must be a relatively simple procedure :(
  11. qbee42
    3,079
    The cost isn't for the procedure (well, a small amount is), it's for the piece of hardware. SKS fobs are expensive little beasts. Try not to lose them.
  12. odysseus
    61
    Austin, TX
    The problem is that used cars often only come with one. So let's say that I want to purchase a used Prius with only one SKS fob. I want my wife to have access to the car as well but not spend hundreds. Should I duplicate the mechanical key, and buy a fob on eBay to be used as a dumb fob?
  13. derkraut
    derkraut Member
    299
    28
    SAN
    I agree with you; but it is what it is. FYI, this applies to fobs for most all new cars these days, not just the Prius.
  14. AndyZaa
    AndyZaa Junior Member
    35
    17
    New Brunswick, NJ
    OMG, I just bought a used 2006 Prius yesterday that came with one Smart Key fob. I just got off the phone with my local Toyota dealer and he gave me a price of $475-$500 for ONE spare. I don't think I would have bought a Prius if I knew a spare key was $500! Is there any alternative for getting a spare Smart Key (not a dumb fob off eBay)? Do different dealers have significantly different pricing?
    I'm in shock.
    Thanks.
    Andy
  15. Rhino
    Rhino New Member
    460
    U.S.A.
    Say you are willing to shell out the money for a new smart fob. Does the new smart fob come with a new mechanical key just like the original?
  16. richard schumacher
    7,664
    1,047
    United States
    Yes. Well, after the dealer cuts it it should be just like the original.
  17. tableround
    tableround New Member
    27
    Grosse Pointe, Michigan
    I called a Toyota Dealer in Marion, Ohio ($120), Delaware, Ohio ($118 for new fob), Akron, Ohio ($127), Columbus, Ohio ($114), and Cincinnati, Ohio ($110). This was just for the key, not programming. All of these dealers wanted $50 for programming. (I'm wondering why the further south in Ohio I called the cheaper the fob, and the further north I called the more it cost?
  18. AndyZaa
    35
    17
    New Brunswick, NJ
    Tableround,
    Was this definitely for a Smart Key, not a "dumb" fob? I'm going to call some other dealers tomorrow and see what I get for prices around NJ.
  19. qbee42
    3,079
    It's part of the cost of ownership. This was a preexisting condition when you bought the car. If you buy a used car with bald tires, you know you will have to pay for new tires. If you buy one with only one key fob, it's reasonable to expect to pay for another.
    I also think they are too expensive, but that's what the market will bear. Just buy a new fob and be done with it.
  20. AndyZaa
    35
    17
    New Brunswick, NJ
    So, thanks to the input from here, I've been calling around to get more detail on costs to get a spare SKS for my 2006. Just to be clear, this is a SKS SmartKey not a "dumb" fob.
    The dealer who originally told me to expect a $500 bill breaks the cost down:
    SKS remote fob: $219
    Programming cost: $95
    Metal key to fit in the fob: $109
    From the posts here, I thought the metal key would be about $8. The service person told me it was a laser cut key with a chip in it. I don't think this is correct, right? It's just a metal key to open the door and has no electronics.
    I mostly understand the difference between laser cut and ground cut keys. It sounds to me like a lot of folks here have purchased blanks for the metal key on their fob on eBay and had them cut conventionally (ground cut?) by a locksmith using the original key as a template. Since it's an emergency key anyway and will get very little use, I thought this would be fine. What are your experiences?
    I also hope to get a regular flat key cut for my wallet as I always have done - that one has saved me more than once!
    I'll report back if I find any significant differences in the dealer prices.
    Thanks for all the great tips!
