Prius Key (non SKS version)
Discussion in 'Gen 2 Prius Technical Discussion' started by mrshow555, Dec 14, 2009.
  1. mrshow555
    mrshow555 New Member
    42
    LA
    I bought my Prius used and it only came with one key. I would like to make a duplicate of the fob to keep at home in case I lock my keys in the car. Can I used a generic lock unlock fob from PepBoys? or if I buy a used Prius keyfob can I program the buttons to work with my car. It's not the SKS key but just the keyless entry buttons.
    I found this tutorial on how to program keys....
    http://priuschat.com/forums/gen-ii-prius-audio-electronics/11929-list-known-hacks-easter-eggs.html
    Also do regular locksmiths do laser cutting or only dealerships? I found cheap Prius key blanks on eBay as well.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    You cannot use a non-Toyota fob. You can buy the black fob (silver is SKS) from a dealer or other source. Programming instructions are on this forum. Do a search to find them.
  3. mrshow555
    42
    LA
    is there anyway to install the SKS system into an old car? is it like a single unit or I'm guessing it's probably way more complicated than that...
    Also are there any commercial places that do cheap laser engraving?
  4. vertex
    vertex Active Member
    672
    144
    new york
    2018 Prius Prime
  5. qbee42
    3,081
    You can't install SKS in a non-SKS Prius, at least not realistically. It involves a transponder, coils, wiring harness, and another ECU.
