Quick "clunky" start-up.
Discussion in 'Generation 1 Prius Discussion' started by ClassicPrius, Dec 10, 2009.
  1. ClassicPrius
    ClassicPrius New Member
    MA
    2003 Prius
    Hello everyone!
    Yes its my first post but i must admit I've been an avid reader of this forum for quite some time now. For nearly two years I have been reading, but never bothered to register because almost everyone has already had asked the same question. However I do have a question and I really hope you can help out.
    I purchased my brilliant blue pearl 2003 prius this summer in july. I bought it from a small dealer with hardly any background info from a car besides that the people that traded it in traded it in for the new 3rd gen. She had ~155k miles on her. Now she has 168K again no problems at all. Until recently though,
    I noticed when it started getting colder when I turn the ignition the engine would fire right up but within 2-3 seconds it would make a quick "Clunky" sound. It stays for about 2 seconds or 3 then goes right back to normal. It only does this when the engine is cold and its been sitting for awhile (like overnight). I can't really think of any other way to explain it. I could maybe post a youtube video if it would help. Although the clunkiness happens fast. Its not a slow long clunk, but a series of quick ones. When i first heared it, it was very quick but now it has gotten a second or two longer. I figure its because of the cold weather and the engine is just colder there for making it clunk longer but it could just be because the problem is worsening.
    I'm sorry if I made this to long. I really appreciate the help in advance and us classic prius owners got to stick together!
  2. bwilson4web
    16,201
    Mine does the same thing. Check your oil level but otherwise, I suspect it is just winter gas. Speculation on my part, I've been thinking of trying a tank of 89 octane just to see if it is a winter-gas, knock. I just haven't tried it yet because it doesn't seem that big of a problem.
  3. ClassicPrius
    MA
    2003 Prius
    Thanks for the response Bob Wilson! You don't know how relived I am! Anyways I will check the oil level and I'm nearly out of fuel so I will fill'er up with some premium gas and let you know.
    Thanks again-
  4. kenopa
    kenopa Junior Member
    57
    Indiana
    Yup, mine sounds like that whenever it's really cold. Thought it was the gummy throttle plate but now I agree with Bob. Been doing that now for four years. Just had 120,000 mile service and got away clean. I have had other non-hybrid vehicles that had similiar "clunky" starting symptoms. So enjoy your ride.
  5. Patrick Wong
    18,200
    6,502
    87 octane fuel (regular grade) is recommended for Prius. Higher octane may cause engine problems.
    If you wish to experiment with midrange or premium I suggest that you buy just a couple of gallons so that you can easily reverse the experiment (by filling the rest of the tank with regular) if you need to.
  6. bwilson4web
    16,201
    Patrick is right, a partial tank of higher octane fuel for experimental use makes sense.
    I had the clunks Thursday after using the block heater. A 'thin' oil hypothesis also makes sense.
  7. orange4boy
    orange4boy Member
    231
    44
    Vancouver BC
    2003 Prius
    Mine does it too. My guess is valve train noise. Possibly the chain or a sticky lifter. viscous oil can make the valve train clack a bit when cold. Happens on many cars. Nothing to worry about.
    Bob's thin oil idea sounds like the most likely though. The oil on the chain and lifters dampens noise. Although there is a thin layer still present when you start a car, it takes a couple of seconds for the oil to soak everything. Good, fresh oil will be better at protecting your engine during those moments.
    Our 1959 Meteor has sticky lifters that do this sometimes when cold from gummed up valve guides. I took off the valve cover to watch. A few squirts of WD40 on the stems got them moving almost instantly. Most modern engines don't have the sticky lifter/valve problem anymore.
  8. patsparks
    10,664
    567
    Adelaide South Australia
    There are no hydraulic lifters in a Prius. My Prius engine is a little noisy when cold but fine once warm so I'm not too concerned. One day I'll check the valve clearances.
  9. windshearalert
    windshearalert Junior Member
    37
    Little Rock, Arkansas
    2001 Prius
    yes i would agree with all above. I am almost certain is valve clearance noise. Mine does it same as everyone else. Lasts maybe 2-6 seconds on initial startup and then gone. Has anyone on here ever set the lash? I looked it up through the mainenance manuals and looks like you have to have the correct shim buckets. Its not a easy service to have done and it would probably cost quite a bit to have done. Each bucket needs to be checked/ measured and replacements depend on clearances for each bucket on intake and exhaust. I have been curious if anyone had it done at dealer and price?
  10. Patrick Wong
    18,200
    6,502
    Ignition timing is retarded upon cold startup for several seconds. The purpose of this is to help heat up the catalytic converter. Maybe this is causing the engine noise reported in this thread.
    I removed the valve cover on my 2001 at ~60K miles and found that out of 16 valves, 4 had slightly more clearance than spec. However it looked like too much trouble to remove the camshafts in order to access the buckets, so I contented myself by replacing the PCV valve and reinstalling the valve cover.
