Don't forget about the air flow vent in the backseat
Discussion in 'Gen 2 Prius Main Forum' started by rocco, Jul 5, 2005.
  1. rocco
    rocco Member
    146
    FL
    While driving to the beach yesterday my daughter and her friend brought "pillows" big down fluffy bed pillows so they could sleep on the 90 minutes trip.
    After about 20 minutes my Darling Daughter (15 yrs) tells her friend to Move off the air flow vent back there.
    IT never even occured to me. Thanks to my daughter - I won't likely forget now
    but what if any damage could I have done?
  2. rocco
    rocco Member
    146
    FL
    Now that I'm on that subject (of the Beach) - San Destin - and YES I did go swimming :)
    I also brought my poochi rocco and since he wasn't allowed on the beach I sat in the car with the air running for about 2 hours.
    The battery would drain, then I guess the engine would kick in and recharge the battery, a cycle.
    does that do any harm to the engine?
  3. rocco
    rocco Member
    146
    FL
    Anybody? anything happen if you cover that vent in the back for a long period of time?
  4. Danny
    Danny Admin/Founder
    7,093
    2,122
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    The answer to the 2nd question is no. The answer to the first question is probably not. Blocking that vent for about 20 minutes shouldn't have done any damage, at least in my mind. I believe if there was any overheating the HSD system would have taken care of the problem itself or at least notified you via dash instrument warnings.
    If you haven't noticed anything different, I wouldn't worry.
  5. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
  6. KTPhil
    KTPhil Active Member
    1,379
    22
    I think you'll get a warning about battery temperature, and it may run ICE-only until things return to normal.
    p.s. You posted twice times in 90 minutes withe the same question. On the cold expressionless web, that comes across as impatiently demanding an answer, not politely asking for it.
  7. Danny
    Danny Admin/Founder
    7,093
    2,122
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    You calling PriusChat cold and expressionless???
    :lol:
  8. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(KTPhil\";p=\"104283)</div>
    At least both messages were posted in the same thread as opposed to some members who repeat the same questions in multiple threads in numerous forums.
  9. rocco
    rocco Member
    146
    FL
    OOps? :) thanks yous
  10. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    <div class='quotetop'>QUOTE(rocco\";p=\"104238)</div>
    Here are 20 points -- but give them to your daughter! Good show on knowing about the vent!
  11. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    <div class='quotetop'>QUOTE(Danny\";p=\"104292)</div>
    We're like Mr. Spock -- logical and emotionless on the outside, but a big ball of warm goop on the inside. :)
  12. Tideland Prius
    16,589
    I guess if the battery starts heating up, it'll start using it less often. Also, you may hear a fan first as it tries to draw in cold air.
