What brand gasoline do you use?
Discussion in 'Gen 3 Prius Main Forum' started by GreenGuy33, Dec 18, 2009.
  1. GreenGuy33
    GreenGuy33 Active Member
    534
    29
    Rhode Island
    Do you use a particular brand of gasoline? Or do you feel it doesn't matter?
  2. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    My experience with all of my Hondas and Toyotas is they will burn anything. I think it's a good idea to stick to the major brands but when I have burned off brands, I have never had a problem.
  3. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    I stick with whatever is cheapest. Usually it's an independent near my house, sometimes a Rotten Robbie near work.
    Edit: Over 67k miles on my car with no problems (knocks on my head).
  4. Fstr911
    Fstr911 Member
    235
    55
    Chevron, but primarily because the price is fair and it's right down the street.
    While I fill my car I've noticed the ad by the pump indicating that an additive Techtron (or whatever they call it) is supposed to keep the engine cleaner. Who knows, but you asked what we use, so there we are.
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    When I pay, Kroger or Walmart gas, when work pays, Shell. Shell is often 12 cents a gallon higher, but they have a corporate card.
  6. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Exxon, only because using their Exxon Mastercard I get .15 a gallon deducted from my bill.
  7. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    Mobil or Sunoco....Have not had any issues.
  8. eaglesight333
    eaglesight333 Senior Member
    6,956
    81
    Northern, IL
    As I have stated in other Gas Threads. I stick with Shell or BP. Even though they a bit more expensive. I used cheapo gas in my old car, which I discovered was giving my car engine and piston issues. Once I stopped with cheap-o gas, and went with brand name. Made a world of difference. So, even though it is more expensive, I will not use cheapo gas again
  9. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    Currently, Chevron since its cheapest (currently $2.87) among Shell/76/Exxon on my commute path. I used to use Costco but I can't use my visa card there which giving me 5% rebate on gas. Almost all gas in the area come only from a couple of distribution centers but only difference is additive pkgs as far as i know.
  10. djasonw
    djasonw Active Member
    961
    123
    Coconut Creek, FL
    I actually use a variety (Hess, Getty, Mobil) and do not notice any difference at all. I do notice that when I fill up in New Jersey I get better gas mileage. I can't figure out why. Now that we're on the subject of fuel, does anyone know why SHELL and GULF are priced significantly higher than the current average?
  11. snijd
    snijd DIY or die
    243
    52
    PNW
    Regarding performance, I've had good luck with Shell. As far as socially-responsible behavior, Sunoco and BP (Arco, Amoco, am/pm) seem to be the best. Exxon-Mobil is at the bottom of the barrel (pun intended).
  12. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Usually Costco if I happen to be there, it's about 25 miles from home. Around home I use either Shell, Standard, or Short Stop Store gas because they are convenient. When I travel I look for clean well maintained stations that appear to be used a lot. I have never had a problem with gasoline as far as I know.
    You can buy the Techron additive at quite a few stores in 16 oz bottles, I don't know it helps or not. I bought a case of it for my previous car (the manufacturer recommended it) and I have some left so I dump in a bottle when I change the oil. I have heard you shouldn't use it to often.
  13. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    The cheapest 87 octane I can find. Costco, BJ gas offer the lowest cost I can find
    Dbcassidy
  14. mindmachine
    mindmachine Member
    394
    79
    Ohio
    2014 Prius Plug-in
    Speedway for the speedy rewards program with my speedway mastercard equals about 8% off the price.
  15. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Usually Costco, since it's ~$0.30 (10%) cheaper than any other gas station around.
  16. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    comment deleted
  17. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    No matter what it says on the sign, you don't know what thy are really pumping.
  18. F8L
    19,011
    4,083
    Grass Valley, CA.
    Thanks for saving me the effort of posting that. :)
    I generally us Arco-AM/PM when possible.
  19. Jim05
    Jim05 Occasional Quasi-Hypermiler
    115
    Culpeper
    Shell, or any other top-tier I can find. The bit extra you pay over the bargain basement junk is more than made up in the increased mpg and cleaner engine.
  20. Koyanishi
    Koyanishi Junior Member
    Laredo
    Top Tier gasolines are supposed to reduced deposits in the engine because of the additives used in the gasoline, therefore I use only top tier gasoline.
    Do a google search on top tier gasoline.
