Jerking Forward While Stopped
Discussion in 'Gen 3 Prius Technical Discussion' started by TurtleHare, Dec 28, 2009.
  1. TurtleHare
    TurtleHare Guest
    After stopping (and usually when slightly angled downward), when the gas engine stops the car jerks forward as if someone lightly hit you from behind.
    Is it my sensitivity to the hybrid system or are others also experiencing the "phantom rear-ender?"
  2. qbee42
    3,079
    Sensitivity. When the ICE kicks on or turns off, there is some torque applied or removed from the drive train. It's normal. If you keep your foot on the brake the car doesn't move.
    HeadOfJarg and (deleted member) like this.
  3. bestmapman
    1,289
    242
    Kentucky near Cincinnati, OH
    I have never experienced this.
  4. bwilson4web
    16,161
    Can you take a photo of the intersections where this happens?
    Any ice about?
  5. mmichaell
    mmichaell Member
    241
    chicago
    I got this twice today with the Prius III I bought a week ago, when the car was parked. Yes, it seemed as if the car jerked forward when the engine stopped. But I think it is a normal thing - we're just not used to it since most non-hybrid cars don't have the engines stopping when you're at a light or idling.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Happens nearly every time my cold engine starts up (w/o brake on)... it just a very light jerk, enough to rock the car on the pawl.
  7. rrlerner
    rrlerner New Member
    Northeast
    I have had a lurching sensation when going over manholes. Fortunately, when I applied the brakes, i had control over the car. i did not like this happening. I have not reported it to my dealer, abut I think I will now after having read the article at msnbc.com about the prius and brake problems.
  8. qbee42
    3,079
    This is not the same issue as that described by the OP. What you are describing is a loss of traction, which forces the Prius to transition from regenerative braking to ABS friction brakes. This is normal.
  9. robomoto
    robomoto Member
    78
    Surrey, BC, Canada
    I solved this problem on my 2010 prius by upgrading to Akebono brakes
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,147
    Tampa, FL
    This thread died 10 years ago and the OP has never returned, but it originally was about the car feeling like someone lightly bumped you from behind while you're stopped. I used to get this in my '05. It took me a while to figure it our, but it had to do with the warm-up stage it was in. It only happened at a certain point in the warm-up and didn't do it before or after that temperature.
