Check engine light and HUGE discrepancy between computer and gas gauge mpg – any ideas?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Frizzy_Lizzy, Dec 30, 2009.
  1. Frizzy_Lizzy
    Frizzy_Lizzy New Member
    Wisconsin
    Hello all!
    We bought our used 2008 Base model Prius (Magnetic Grey) last week. It has around 14k miles on it, and has good maintenance records.
    On Sunday, we were driving around the mall, and the check engine light came on - not the maintenance required light.
    We're planning on taking it to the dealer tomorrow to get it checked out, but here's what we noticed today: We left the dealer last week with nearly a full tank of gas. We've driven a little more than 200 miles since then, and the computer display says we're averaging at about 43 mpg (it's cold, slushy, and icy here, so we're pretty happy with that number), but the fuel gauge is telling us the tank's nearly empty - and I know the fuel gauge isn't 100% accurate, but, according to my math, that's WAY off - like 20 mpg off. :confused:
    Any ideas on what's going on?
  2. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    1) Dealer 'fill' may have just been enough to light the top pip, rather than truly full. If so, your top pip would have gone away quickly. Fill the same way each time: I'm a 1st click=done type, but others go to 2nd or 3rd shutoff, still others fill until the neck is full. I sacrifice tank by tank accuracy using 1st click, but no risk of spillage or damage to emission systems.
    2) When you get to the last pip, you still have some range left, although you should fill up sooner than later as discussed here many times due to the bladder in the 04-09 models.
    3) Maybe a prankster friend or a thief got to you with a siphon hose.
    4) Maybe there is a fuel leak.
    5) You didn't state how many pips are left, just nearly empty, so we don't know what nearly empty means.
    Suggest you fill up now and record your miles in the new tank by pip (some go quicker than others) so you establish a base line and learn the car's gauge.
    I'm sure things are fine, but you'll want to calculate mpg manually to compare with the car's estimate, keeping in mind that this 1st tank is probably off due to 1 or more of the above, or other factors.
  3. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    I agree with Stathead's assessment of your mileage issue. I suspect it wasn't actually full when you drove it off the lot. Like any fuel gauge, the Prius' gauge does not map linearly. I've gone anywhere from 50 to 300 miles on the first pip, with considerably less on the rest. Don't fret about it until after you've established the baseline he suggests and find a consistent trend.
    The CEL is almost certainly an unrelated issue and would be of greater concern to me. There is no way of knowing what it indicates without knowing whether the car is running properly (though I'll assume it is since you didn't report otherwise), and it probably will require the dealer to pull the diagnostic trouble code(s).
  4. Frizzy_Lizzy
    Wisconsin
    I'm sure the dealer's fill wasn't 100% full (to the tank's maximum capacity), if only because it's been so frigidly cold here in Wisconsin - I don't know anything about hybrid systems, EVAP systems, or cars in general really :rolleyes:, but I've been reading about how the fuel bladder contracts and lowers it's capacity when it's cold out. We've had some single-digit temperatures during the past few weeks, so that's surely a factor.
    We had 2 pips of of this morning, and all the pips but 1 when we left the dealer - another family member took the car to work today, which is about a 20 mile round-trip drive. She was going to get some gas today and then we'll start keeping track of how many gallons we've put in and the number of miles driven - the drive to the dealer tomorrow should be a good test: it's 51.4 miles there and back, or a 102.8 mile drive! I doubt a prankster siphoned off our tank - the car is garaged and we live in the middle of nowhere, deep the the woods - it's a 15 minute drive to the nearest town, an hour to the nearest proper city.
    It's the check engine light that got us so worried. I've searched all over the forums trying to figure out, on my own, why it might have lit up. The car runs beautifully, no problems starting up.
    We finally took the plunge and bought a Prius because we were sick of the "Check Engine" light always coming on the '98 Oldsmobile we were driving - we just don't have any luck! :D
  5. GeekEV
    GeekEV Member
    417
    NorCal, USA
    I believe that (amongst other things) not properly tightening your gas cap can sometimes trigger a check engine light. Reseat the gas cap taking care to make three or four full revolutions with it to be sure it's sealed properly. If that's it, the light should go away after a few trips of 10 miles or more (it doesn't go away immediately). But, since you just bought it, see if the dealer will check the code for free...
  6. ksstathead
    1,244
    245
    Kansas
    Or find someone with a scangauge or other scantool in your area... I completely missed the CEL issue in your 1st post.
    Glad to hear your didn't even have the top pip when you got the car and still had 2 left. I think you are getting roughly the fuel economy the car is reporting. The middle pips can go quickly.
  7. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    AAMCO & some/most? auto parts store will pull a code for free. This is why you should buy a ScanGauge if you don't want the extra instrumentation. My bet is loose gas cap. Sounds like the dealer will do this for free under warranty but you'll waste much more time there.
  8. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    As for the CEL, make sure the gas cap is on tight. If found loose, it will take several start/shutdown cycles for the CEL to clear.
