Removal of "Hood Ornament" Begging your kind indul
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Paul113, Jun 28, 2005.
  1. Paul113
    Paul113 New Member
    56
    Motown
    I know I've read it on here somehwere but I'll be darned if any of the word combinations I've tried in the search hit.
    Is there a good way to remove the Toyota symbol from the "Nose" or hood if you like?? I'm pretty sure it's just on there with that foam backed adhesive stuff that most body apliques are stuck on with these days. Forgive the tortured grammar. I was going to use a hammer and chisel but thought I'd ask for some suggestion in this brain trust first.
    Thanks,
    Paul
  2. popsrcr
    popsrcr New Member
    232
    Richmond, VA
    Re: Removal of "Hood Ornament" Begging your kind i
    If it is just on with adhesive, use fishing line and a hair dryer. Heat it up and go at it with the fishing line. Take your time. When your done there will be adhesive on the car. Use your finger (not nail!) and rub up as much as you can. Then get some 3M adhesive remover and a soft cloth to get the rest off.
    Once you're done, be sure to rewax the nose.
  3. Hybrid_Dave
    Hybrid_Dave New Member
    209
    Richmond Virginia
    Thanks for the info popsrcr...I had wanted to do this as well, but wasn't sure if it was attached with the little pegs, that's good news.
    Dave.
  4. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
  5. Hybrid_Dave
    209
    Richmond Virginia
    <div class='quotetop'>QUOTE(TonyPSchaefer\";p=\"102312)</div>
    for me personally, I like the look of a clean debadged car. The way I see it, I know what I'm driving, and because of the unique styling of the Prius, everyone else on the road does too. but yeah, just because I guess (the answer to why is why not) :p
  6. KTPhil
    KTPhil Active Member
    1,379
    22
    Improves mileage by 0.0000145 mpg due to lowered turbulence and air resistance.
  7. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    Can someone post a picture or two of the hood w/o the emblem? One head-on and one from an angle would be good. In looking at the hood it appears as if there is a flat spot for the emblem, I want to see what it looks like w/o the emblem first. Thanks.
  8. alsgameroom
    alsgameroom Member
    117
    Northern New Jersey
    I'd like to see a pic also.. I'm considering removing my front toyota emblem because I'll be putting a bra on her.
    Not sure yet but I'm thinking the hood portion of the bra will fit tighter and create a better seal from water and dirt getting down in there if I remove the emblem.
    How about the emblems on the rear of the car? are they afixed the same way? I betcha some people out ther might consider removing them also...
    - Al
  9. popsrcr
    popsrcr New Member
    232
    Richmond, VA
    I would be more sure that the rear emblems are on with tape more than the front one.
    As for how it would look, just use photoshop.
  10. Paul113
    Paul113 New Member
    56
    Motown
    I'm going to replace it with one of my bowling trophys. Now aren't you glad you asked?
  11. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    <div class='quotetop'>QUOTE(Paul113\";p=\"102788)</div>
    :clap: :clap: :clap:
    (But what about increased wind resistance and MPG? :mrgreen: )
    [hr:fe8d186fa8]
    Now there's a great idea for a thread: alternative hood ornaments for the Prius!
    Here are some classics that could be used:
    [Broken External Image]:http://image12.webshots.com/13/5/89/12/343758912lkCOfl_ph.jpg
    [hr:fe8d186fa8]
    And some more, umm, unusual ideas:
    [Broken External Image]:http://www.judturner.com/hood_gal/birdhand4_2003.jpg
  12. alsgameroom
    alsgameroom Member
    117
    Northern New Jersey
    The last photo is for BUSH.. right?
  13. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    the bra goes way over the hood ornament. trust me, it won't help make a tighter seal. just to warn ya. :)
  14. KTPhil
    1,379
    22
    Just because she's got a bra on doesn't mean "protusions" aren't a welcome sight.
  15. Danny
    Danny Admin/Founder
    7,093
    2,120
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    At least on my MR2 there are 2 prongs that go into the front bumper as well as the adhesive backing. Good luck - let us know how it turns out.
  16. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    And Paul113, please -- if possible, post a picture of your bowling trophy hood ornament on your Prius!
  17. Paul113
    Paul113 New Member
    56
    Motown
    Looks like the bowling trophy stays on top of the TV next to the rabbit ears with the tin foil on em. The nose cone emblem is located on 2 pegs that fit into 2 small sleeved holes in the hood. and the area that the badge sits on is flat as some astute poster earlier correctly suspected.
    So the nose badge stays. :cussing:
    Namaste,
    Paul
  18. alsgameroom
    alsgameroom Member
    117
    Northern New Jersey
    I just took off the hood ornament on my new prius. Guess what... now I have 2 lovely holes where pins go. Sawed the pins right off with the fishing line!
    its going back on right now.
    thanks for the tip NOT :guns: :guns:
  19. Hybrid_Dave
    209
    Richmond Virginia
    well, that sucks...sorry you had to find out the hard way, but thanks for warning those of us who would have attempted....
    Dave.
  20. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    :( There is a political forum elsewhere. Spare us your political BS.
