Speedometer Accuracy
Discussion in 'Gen 2 Prius Main Forum' started by genalex, Jul 8, 2005.
  1. genalex
    genalex Member
    265
    Jersey suburbs of Phila.
    Driving I-295 in a 55mph zone, I find that everyone's passing me 'till I bring it up to 65. When I enter the 65mph zone, where fines are doubled, I have to go at least 72 to keep up. Is it me or is it them?
    I know the mechanical speedo in my '96 Camry was fast, but I would expect the digital Prius with in-flight economy readouts to be on the money.
  2. Tideland Prius
    16,508
    All speedometers are inaccurate. The worse are German cars (for obvious reasons). The closest to true readings are American cars.
  3. genalex
    genalex Member
    265
    I did find that my '86 Accord was "on the money".
    Clocked it on measured miles.
    I guess I should do that again with the Prius, unless someone has already done so.
  4. Tideland Prius
    16,508
  5. Sufferin' Prius Envy
    3,998
    Sacramento tends to have a bunch of these portable radar displays on the road.
    [Broken External Image]:http://www.papd.org/graphics/smarttrailer1.gif
    Every time I see one and look at my speed, they are the same.
    I have yet to see one in a 55 or higher zone, so I can’t vouch for the Prius speedo at that speed.
    Once you start really flying . . . say near the speed of light . . . I’m positive the Prius speedo is highly inaccurate. That dang time shifting thing really screws things up. :x
  6. skew
    skew Junior Member
    71
    According to my Kenwood navigation its within .5 mph its almost always the same. I'm sure running 42/40 psi in my tires is the difference between the two.
  7. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    When I changed tires, I was supposed to be 2% off. I am now supposedly going faster than I think, but people still pass me. I believe it has more to do with following the speed limit (or not) than mechanical inaccuracy...
  8. RBW111
    RBW111 New Member
    139
    El Dorado, AR
    As compared to my hand held GPS unit, my Pri was showing 2 mph less than actual.
  9. c4
    c4 Active Member
    607
    51
    My Garmin GPS unit shows that on my Classic, the speedometer is dead-on (up to the limits of a whole number speed readout) up to around 90 km/h, and then a slight discrepancy starts to show up, so that at 100 km/h, the GPS actually shows 102-103 km/h. I've got the 185 sized Michelin Hydroedge tires on the car, which would account for this. I haven't gotten around to checking what my recently installed nav system says, but I'm betting it would be the same as the Garmin GPS..
    In contrast, on my old Corolla, the speedometer was likewise dead on up to about 80 km/h, and thereafter, it read high, so that at 100 km/h, I was actually only going about 98, and at 130, the car was only doing 120..
    The old 94 Jeep Cherokee we use at the barn is dead on with the GPS throughout its range..
    I think that most speedometers are built to have most accuracy in the low speed range (0-80 kph/0 - 45 MPH)
  10. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    I don't know how the US models are adjusted, but it looks the Japanese 2004 Prius was built following "ECE Regulation No. 39".
    http://www.unece.org/trans/main/wp29/wp29r...regs/39rv1e.pdf
    On the last page, it says...
    0 < or = display error < or = (real speed)*0.1 + 6km/h
    The Japanese Prius displays about 6km/h higher than real speed when the vehicle speed is 40km/h or higher.
    Ken@Japan
  11. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    According to my Garmin when I drive 60 I am really going 59.
    This 1 mph difference seems to hold from about 30 to 70 at least.
  12. kirbinster
    kirbinster Member
    602
    Morris County - New Jersey
    <div class='quotetop'>QUOTE(Tideland Prius\";p=\"105317)</div>
    Come on now. I have a BMW 740iL and have timed it at exactly sixty seconds when traveling at what it claims is 60mph on a measured mile.
  13. 200Volts
    200Volts Member
    439
    46
    Northern CA
    My handheld GPS shows my speedo is reading 1 mph fast at 70mph (cruise control on) and the radar gun speed signs show the same error at 50mph.
  14. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    <div class='quotetop'>QUOTE(genalex\";p=\"105315)</div>
    [font=Comic Sans MS:0c2f9c81bf]So there are a lot of inaccurate speedos out there, almost all showing a higher speed that reality. This means, IMHO, that all those people passing you are SPEEDING. If you have any questions about this, call up you local highway patrol and ask what the "real" average speed is on your local freeway.
    Just cruising along in my Silver Cloud....[/font:0c2f9c81bf]
  15. naterprius
    naterprius Senior Member
    1,843
    Hey! The speed displayed on the diag screen of the NAV system and the speed on the dash is way off! Almost 5 mph faster on the dash at 65 mph!
    Someone else try this with their NAV system and get back to me.
    Nate
  16. Fredatgolf
    Fredatgolf New Member
    339
    Pinehurst
    <div class='quotetop'>QUOTE(genalex\";p=\"105324)</div>
    We checked our Prius at 45 and it was dead on.
