My Prius itech 2009 is turning on by itself!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Aprille, Jan 6, 2010.
  1. Aprille
    Aprille New Member
    Sydney
    I'm hoping that someone might have experienced the same thing. I've taken it in to the Toyota Dealership and the mechanics have checked it over and they can't find anything wrong. My car was parked and I was in my home when 2 people from my block over the past 2 weeks has told me that on seperate occasions my car turned on by itself! One time the guy from my block was having a coffee near my car when it turned on for about 60 secs then turned off on it's own, he came and told me what had happened, then a week later there was a knock at my door and the lady downstairs told me my car was on. Has this happened to anyone else. HELP!
  2. ibmindless
    ibmindless Member
    206
    What procedure do you use to turn the car off? It sounds as though somehow, the car is NOT turned off and therefore the engine cycles on when necessary to recharge the main battery.
  3. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    I agree, it sounds as though it wasn't really off.
    FYI, this sub-forum is for discussions about the functioning of the PriusChat Website, not car questions. I'm not trying to play forum police, just trying to help you get answers. Some who can help you with your car may not be looking here. You might consider asking the moderators to move this thread.
  4. dogfriend
    7,512
    1,189
    Carmichael, CA
    Can you define "turning on"?
    Is the car turning on to "Ready"? or
    Does the dome light come on when you approach the car?
    The first shouldn't happen if you shutdown normally, the second one is normal with SKS.
  5. richard schumacher
    7,664
    1,042
    United States
    I'd bet a dollar the OP meant that the engine was running. If so the problem is that the OP was not turning the car OFF.
    Always lock the car when you leave it; if a door is not completely closed or if the car is not OFF it will give a long warning beep.
  6. Aprille
    Aprille New Member
    Sydney
    Thanks but I turned off the car and locked it when I checked the car was on ready. I appreciate all your responses but it has me baffled completely I've had the car a year now and its never been a problem until 2 weeks ago. I'm very new to this site so I apologise that I placed this in the wrong area on the PriusChat site.
    cheers
  7. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    Would it be possible to setup a video camera inside the car to document it turning itself on?
    Do you have any other people in your household that may have access to the key that may have gone for a joyride?
  8. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Ghost.
  9. Aprille
    Aprille New Member
    Sydney
    Unless my cat can drive...no.:) But what a great idea to set up a camera inside the car...yes that is exactly what I will do! Thanks
  10. Bob64
    1,540
    93
    Virginia
    If you do manage to catch it on tape, it'll be sure to convince the dealer/toyota that something is truly wrong. Post it here too - as of now, I'm skeptical as well, I'd probably have to see it to believe it.
  11. patsparks
    10,664
    567
    Adelaide South Australia
    Try this
    Leave the park button alone and only use the power button when you want to shut down. If you miss-hit the power button the car will alert you when you open the door telling you to put the transmission into park. If you put the transmission in park before hitting the power button this wont happen. Don't worry, if the car shuts off it will go into park on its own.
    Another thing, from time to time the brake pump might run when the car is shut down, this might be what is happening and what people are hearing.
  12. RobH
    RobH Senior Member
    2,373
    987
    70
    Sunnyvale, California
    This sounds exactly like what happens when I intentionally leave the car in Ready mode. During really hot weather, I will sometimes park the car at the market, leaving the car in Ready with the air conditioning ON. I set the parking brake, press the Park button, and turn off the MFD screen. Then I get out and lock the doors with a mechanical key. The engine cycles ON about 1 minute out of 5, and I return to a car that is already cool.
    Several people have noticed it, and I explained that I've left the electric air conditioning ON, and the engine has to cycle ON every so often to recharge the battery. Everybody so far has thought that it is a really neat feature.
  13. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    The last part of your statement is confusing. Please answer the questions "What procedure do you use to turn the car off?" and how do you confirm that it's off?
  14. richard schumacher
    7,664
    1,042
    United States
    Before you set up the camera, have a friend take video of yourself turning the car OFF and locking it, showing all button pushes and foot position and the dash lights.
