What happens in Warp Stealth
Discussion in 'Gen 3 Prius Technical Discussion' started by kgall, Jan 15, 2010.
  1. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    So I'm cruising at 70 or so, and go out of cruise and the instantaneous MPG goes to 100, or if I'm looking at the energy flow diagram, energy flow from the ICE disappears.
    Ken1784 tells me this is the condition folks call "warp stealth" because you are going so fast that the ICE has to turn, but it is not burning gas, and if you are using energy, its coming from the battery. Indeed, if I'm going downhill, I find I'm sometimes charging the battery slightly.
    So, what's going on with the ICE? Is it freewheeling? Is something driving it?
    Just curious . . .
  2. bestmapman
    1,289
    242
    Kentucky near Cincinnati, OH
    In the Gen III, Warp Stealth is not the same as the Gen II. It is much harder to obtain, and if you do not have a scan guage or something that can determine fuel flow, then you have no indication of when you are burning gas or are not.
  3. dogfriend
    7,512
    1,189
    Carmichael, CA
    In the Gen 2, MG1 will use battery power to spin the ICE, but no fuel will be used. You can see this with a Scangauge if you use fuel flow (GPH).
    The reason that the ICE is spun is to prevent overspeed of MG1; by spinning the ICE, MG1 can spin slower than it would if the ICE were stopped.
  4. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    You, very quietly, end up on the other side of the universe. :)
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    ICE would be idling around 1,000 RPM on HV battery instead of using gas.
  6. dogfriend
    7,512
    1,189
    Carmichael, CA
    Yep. It is usually about 960 rpm, but I have seen it climb to 1100 - 1200 rpm at higher road speeds (> 75 mph). There is a long downhill that I have gone down many times - if I crest the top of the hill at 60 - 65 mph, I will end up at about 78 - 82 by the time I hit the bottom.
  7. 924danimal
    924danimal New Member
    31
    College Park, MD
    And if you reach 88 mph, you can go anywhere in time. :)
  8. dogfriend
    7,512
    1,189
    Carmichael, CA
    I have made it to 88, but no time transport occurred. I think that the ICE may restart at 92 - 93 mph, but so far I haven't had the opportunity to try it. ;)
  9. qbee42
    3,079
    You probably needed more plutonium.
  10. dogfriend
    7,512
    1,189
    Carmichael, CA
    What if I just collected a couple of hundred smoke detectors and stowed them in the cargo area? Would that be an acceptable substitute? :madgrin:
  11. kgall
    kgall Active Member
    984
    152
    Maybe not. Toyota has announced some new metal purchases, allegedly to power their new batteries.
    But Scottie tells me it's to synthesize di-lithium crystals.
  12. RebelScum
    RebelScum New Member
    48
    Falls Church, VA
    And, as we all know, the only place to get that is from Libyan terrorists.
  13. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    If it doesn't work, then you can always try a lighting bolt.
  14. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    Which you may find here, but they seem to sell only uranium.
  15. Flaninacupboard
    Flaninacupboard Senior Member
    1,297
    213
    Midlands - UK
    I'm afaird you'll need more than a few hundred, try 1,955.
  16. lonestar
    lonestar New Member
    17
    central Texas
    There is an explanation now for Gen II. So what happens in Gen III and how do you get into Warp Stealth with a ScanGuage?
  17. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    Without getting into discussions about used pinball machine parts:
    My understanding of what people call warp stealth is just an overrun fuel cutoff, but with (some) positive electric drive torque. Cars have had fuel cutoff since the early 80's.
    In a regular car: You're at high speed and don't need engine power (for whatever reason). You back off the gas totally, and fuel shuts off, but the engine still turns, being overdriven by the transmission.
    In the Prius, instead of waiting until zero power is called for, they can cut the fuel when the power demand drops below some number of hp that the motors can provide. The engine still has to spin because there's an RPM limit on MG1, but the power to the wheels and power the spin the (fuel-cut) engine comes from the motors. You're on battery power, and the fuel's cutoff, but there's still some power to the wheels, from the motors.
    When the speed drops slow enough that MG1 can keep up with the ring gear, at 0 planetary carrier speed, then it lets the engine stop turning, and you're in regular stealth.
  18. bwilson4web
    16,105
    I don't know but you might ask over in the fuel economy forum.
