possible 2007 owner soon
Discussion in 'Gen 2 Prius Main Forum' started by larry9901, Jan 17, 2010.
  1. larry9901
    larry9901 Junior Member
    44
    michigan
    i see i am in the wrong forum. Going to post to newbies!
    sorry for the mixup
  2. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    Check out the 2007 Prius eBrochure to find out what equipment was standard and what equipment was in each option package:
    [​IMG] 07_prius.pdf
    Also, if you do get the 2007 Prius, it's very handy to have a PDF of the Owner's Manual so that you can do fast word and phrase searches:
    [​IMG] 2007 Prius Owners Manual.pdf
    and table of contents:
    [​IMG] Table of Contents 2007 Prius Owners Manual.doc
  3. dogfriend
    7,512
    1,189
    Carmichael, CA
    A 2007 with Nav but without factory leather should be a package #5. (With factory leather is a package #6).
  4. larry9901
    44
    michigan
    thanks,
    is it asking to much for a carfax? the vin number is JTDKB20U777600646
  5. dogfriend
    7,512
    1,189
    Carmichael, CA
    I don't have a Carfax subscription.
    Re: Minor rear damage - What to check:
    Check to make sure the SKS (Smart Key System) works to open the hatch. The antenna is located behind the rear bumper. With the SKS fob in your possession, the hatch should unlock and open by placing your fingers on the rubber covered latch release above the rear license plate.
    Check to make sure the hatch opens and closes smoothly. It usually takes a good strong push downwards to close completely.
    The 12v (Auxillary) battery is located in the right rear corner of the cargo area. You may want to check out this area to make sure there is no obvious damage to the battery or the brake system reserve module located next to the battery.
  6. larry9901
    44
    michigan
    Thanks dogfriend,
    Is that pretty much all too look out for? anything else that pertains to a rear end collision?
  7. dogfriend
    7,512
    1,189
    Carmichael, CA
    I can't really think of anything else. None of the other important components are near the rear bumper.
  8. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Going to http://www.toyotaownersonline.com/index.html, registering & entering the VIN shows the car's service history. This Barcelon Red was in Ohio & serviced at Germain Toyota of Columbus. The last service record is dated 10/20/08 at 36021 miles when they "moved disabled vehicle" because it was totalled. I'm sorry, but you are looking at a salvage title so there is no warranty. Unless you are getting the car dirt cheap, run (don't walk) away.
  9. dogfriend
    7,512
    1,189
    Carmichael, CA
    Good call. Don't buy a salvage car.
  10. ibmindless
    ibmindless Member
    206
    Also: If the bumper was hit, then the "egg-crate" shock absorbing material is likely compromised and therefore will no longer offer energy absorbing protection. You would want that replaced.
  11. larry9901
    44
    michigan
    Thanks for the good bit of info. Im bummed though:(
  12. dogfriend
    7,512
    1,189
    Carmichael, CA
    Better to know now than later. Good luck in finding another car.
