Gen III rims (17") on Gen II
Discussion in 'Gen 2 Prius Accessories & Modifications' started by sunstarfire, Jan 20, 2010.
  1. sunstarfire
    sunstarfire New Member
    34
    Munich, Germany
    Hey all, noob here :)
    Great treasury of knowledge, I am impressed like hell concerning what you can do to your Prius. I had a Cobra and was busy modding that, now I am delighted to see it's doable on a Prius, too :)
    Anyhoo: Anyone know wheter the bolt pattern on the Gen III Prius is the same as on the Gen II? Meaning: Can I take the (pretty cool if you ask me) 17" rims of the Gen III and put them on a Gen II?
    ingo...
  2. J.Wilkie
    J.Wilkie 80 Mile Daily Commute
    157
    Behind The Orange Curtain
    Maybe call a Toyota dealer?
  3. ken1784
    ken1784 SuperMID designer
    2,943
    1,381
    67
    Yokohama, JAPAN
    Yes, the Gen3 rims fit on the Gen2.
    Following is copy of my post.
    2004-2009 Prius
    15X6JJ: 5X100mm PCD, 45mm offset
    16X6JJ: 5X100mm PCD, 45mm offset
    15X6J: 5X100mm PCD, 45mm offset
    17X7J: 5X100mm PCD, 50mm offset
    Ken@Japan
  4. F8L
    19,011
    4,083
    Grass Valley, CA.
    You could do better (lighter) and cheaper by using an aftermarket wheel. Even the Scion tC wheels look better on the GenII but are very heavy.
  5. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    Well, I have to disagree. The Scion TC wheel is OK, I even had them on my Gen II for about 1.5 years. But it is a heavy wheel and I ultimately went with something much lighter, Ray's Gram Lite wheels 17".
    As for the Gen III 17" wheel I really like it. It is an example, for me, of a factory wheel I would likely keep on my car when I get a Gen III V Prius. Very simple, clean design which looks easy to maintain.
  6. sunstarfire
    34
    Munich, Germany
    Thanks for the replies, folks. I got the same info from a dealer I asked. And I agree with cairo94507.... Those rims look pretty decent for factory ones, and I had a guy sell them here for 500 bucks, whith tires, which is pretty cool. So I guess I'm gonna go for them.
  7. subarutoo
    subarutoo New Member
    1,213
    Chatsworth, CA
    Please post pictures when you get them fitted. I like the new wheel, too.
