MFD issues on '04/'05 Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by efusco, Jun 19, 2007.
  1. patsparks
    10,664
    567
    Adelaide South Australia
    Re: MFD issues on '04/'05 Prius
    Yep, you're right Jay. Booking reading lessons as we speak. :)
  2. fatdawg
    fatdawg Member
    131
    55
    Bay Area, CA
    2014 Prius Plug-in
    The clean-only method lasted for about 2 weeks, when the car sat idle for 4 days during vacation, the problem started up again. Therefore I thought I'd give the soldering a try, per instructions given by hobbit.
    Cheap tools will work, if you feel adventurous, you can fix it for $10-$15. Luckily I had all these old tools in my toolbox.
    I used a cheap old soldering gun, copper wire (hammered down to make the end sharp), solder, and a magnifying glass (unable to see details but helped). It worked! I haven't soldered anything for a long time, re-flowing the connections was fairly easy, I did 4 of the connections next to #60.
    Good luck to those who want to try it out.
  3. patsparks
    10,664
    567
    Further confirming my thoughts: - http://priuschat.com/forums/gen-ii-...923-mfd-issues-04-05-prius-26.html#post984717
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I used to sit back and say "Wow, I'm glad that hasn't happened to me...".
    I've noticed over the past 6-9 months that our 2004's MFD was a bit sluggish at times. Now starting a few days ago, my wife's been reporting the same "external system not connected" errors, along with missing NAV voice, etc. She finally left the car on for me so I could see the issue in action. Seems to be after the car has been in the heat for some time. At 117k miles, it'd far past any warranty. Sounds like I may be attempting to solder, or doing some eBay bidding for a used MFD.
  5. HTMLSpinnr
    5,341
    920
    251
    Pulled the screen out today, soldered on one plug, realized it was the wrong board, then went at the correct board. Took Hobbit's idea of a wire on the tip of my cheap 30w soldering iron. It, and a pin to keep the solder out from between the connectors seemed to work. It doesn't take much solder (I too used the good 'ol non RoHS 60/40) to get the job done. Kinda wish I had steadier hands and more than a 2x magnification on my wife's Ott-Lite, but managed anyway. The test points are quite useful in checking continuity of your work, but you need good clean tips on your multi-meter.
    One thing worth noting is to be aware of the alignment of the frame when putting it back together. There's room for adjustment and allowing it to fit incorrectly angles the screen incorrectly, leaving a nasty gap between the beazel and the screen.
    I sorta cheated getting to the screen, didn't remove all panels left to right, but instead loosened them up just enough to get the 10mm socket wrench in to remove the left bolt.
    Only time will tell how long this "fix" will hold. Thanks again to Hobbit for digging into this.
  6. djasonw
    djasonw Active Member
    961
    123
    Coconut Creek, FL
    You guys are adventuresome and handy. I have two left thumbs so I have 1 more year of extended warranty on my 2004. I hope something happens before then!!
  7. Prius BMXER
    Prius BMXER New Member
    Columbus Ohio
    Well, I almost got in an accident yesterday and narrowly avoided it. But in the process of bracing myself and the subsequent sudden stop, I cracked my MFD. Now, the LCD is in perfect working condition (no bleeding or discolorment). It seems that the glass in front of the screen is the only problem.
    I've read the manual on how to remove the MFD, but I'm curious if I can just replace the glass with Plexiglass?
    The only reason I think this can work is because i've done it with my iPhone when the screen cracked (Fix your broken iPhone screen for $5 - SlashPhone.com)
    Is there an online schematic or whatever of the MFD itself? Is the glass in front of the LCD removable?
    If this wouldn't work, where is the cheapest place to get a refurb unit?
    I live in Columbus, Ohio and the Prius is a 2004(with NAV).
    Just hit the 150k mark too!
  8. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
  9. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    I've got a new chapter in the MFD saga, bringing to light what
    might be another factory assembly problem that could contribute
    to the difficulty. Read about it HERE.
    _H*
    2 people like this.
  10. patsparks
    10,664
    567
    I bow dow to you Mr. Hobbit.
    We are not worthy.
    I thought I recalled something about this in the original series you did. I remember when I re-assembled mine I was careful to assemble it so as to put the minimum stress on the plug by allowing the board to find its own centre before tightening the screws.
    Just so you know, my MFD is still working perfectly about 2 years later.
    Best $25 I ever spent. If I ever see you Hobbit I'll get you a drink or 6.
  11. Patrick Wong
    18,200
    6,502
    Hi Hobbit,
    Great analysis, thanks for adding so much to our understanding of the MFD failures. However I disagree with your concluding comment:
    "But the other important thing is that during reassembly, the four screws are partially threaded in but the rear board / connector mating angle is allowed to settle to its more relaxed position before the screws are actually tightened down. I'm really thinking that just doing that may actually help not-quite-failed-yet units continue working much longer than they otherwise would. Perhaps two more years hence and if enough '04/05 owners try it before their units actually fail, we'll actually be able to tell if it helps."
    The 2004/2005 models are now 5-6 years old. If the MFD hasn't failed yet, then there's no reason to remove it and open it up.
    But, if the owner is going to the trouble to open it up, then he or she might as well resolder pin 60 as well as any other questionable solder joints identified via visual inspection.
  12. looneysbin
    looneysbin New Member
    Colorado
    Thanks to Hobbit for the investigation into this issue and to patsparks and many others for the encouragement to fix the solder joint myself! A couple weeks ago (at about 86,000 miles) my MFD started acting up with the previously described symptoms (stereo turning off, no temperature or other data displayed, check a/c connection message, etc.) I made an appointment with Toyota service, but before I took my car in I found this forum! My husband and I decided to attempt the fix ourselves. The disassembly of the dash was a minor challenge, but not too bad. We quickly located pin 60. Out of sheer luck, my husband works with a NASA certified micro-soldering expert. He quickly found a "Grand Canyon" sized crack in the solder joint and repaired it. It's been 2 days, and there have been no problems!
    Hobbit et al., I owe you a plate of cookies!
  13. blueheron44
    blueheron44 New Member
    Philadelphia area
    Belated thanks to hobbit--using his detailed fix instructions we were able to find a local friend-of-a-friend with an electronics background and the right soldering equipment. The MFD in our 2004 prius had all the symptoms--the check A/C connection message, buttons slow or not working, the unit would just cut off and then come back on. Toyota quoted me $4,000 to put in a new one. Now fixed, and for alot less than $4,000.
  14. patsparks
    10,664
    567
    I think hobbit is more like a god than a hobbit. I share your joy, I have been there too. My MFD is performing perfectly now, 2+ years after the fix!!
  15. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    :hail:
    I agree. I feel so unworthy ....
  16. Eug
    Eug Swollen Member
    970
    223
    Earth (for now)
    Technology
    I have a Prius 2004 and now my MFD electronics seems to be acting up. Less than 90000 km. Sometimes the radio just shuts off, and once in a rare while, the energy monitor screen just stays blank. The grids and numbers are there, but nothing registers. I also get this message from time to time:
    I got the 7-year extended warranty but when I took in the car they said there would probably be a diagnostics fee, despite my having an extended warranty. What gives? Shouldn't everything be covered, including the diagnostics? I got the impression that the dealership thought the item may not be covered, but they said they'd check, but obviously this worries me a bit.
  17. Patrick Wong
    18,200
    6,502
    Your car has a bad MFD. Typically the dealer will quote a diagnostics fee because in case no trouble is found, or a problem is found that is not covered by warranty, the service dept doesn't want to have spent the tech's time without receiving compensation.
    Assuming that your car has a warranted problem, the dealer should waive that fee.
  18. Eug
    Eug Swollen Member
    970
    223
    Earth (for now)
    Technology
    Good to know. Thanks.
    I would have assumed they would have already known about this issue since it's so prevalent, but I suppose they need to cover themselves.
    P.S. For those of you with replacement (refurb) MFD units, has anyone had a recurrence of the problem, or all new refurbs free of this issue now? Sorry if I missed it in this long thread. My understanding is that 2006 or later Priuses don't suffer this problem, or at least don't suffer it in anywhere near the same numbers.
  19. Eug
    Eug Swollen Member
    970
    223
    Earth (for now)
    Technology
    My local dealer is saying Toyota Canada doesn't cover this as part of the Extended Care Protection. Nice. One big reason I got the extended warranty in the first place was for this issue.
    A new unit is $4000, and a third party exchange program refurb is $1000.
    EDIT:
    After multiple calls to Toyota Canada, they said they'd look into it. The local dealer says it's not covered, they say presumably because it pertains to the stereo system which isn't covered and hasn't been covered in the past. However, both phone reps say it could be considered part of a computer monitoring system so it may be covered, but these frontline reps don't have the ability to make those decisions. So, it's being escalated to a review team at Toyota Canada.
    What a pain. :mad:
  20. Eug
    Eug Swollen Member
    970
    223
    Earth (for now)
    Technology
    So, are there any other Canadians who have recently tried to claim this under Extra Care Protection? If so, have you been successful?
    These are the covered items. (Looks like this list is for Lexus, but I'm guessing it's more or less the same.) I see nothing about the MFD specifically, but I do note that the MFD displays engine status and controls the AC unit. If it was strictly for the audio system or something I could most definitely see them excluding coverage for it, but it's not strictly for the audio system.
    Any recommendations for techs in Toronto who might do Hobbit's solder fix? I've done this sort of thing before on a similar failure on an old (multi-region) DVD player, but the connections were much larger and therefore easier to deal with for n00bs like me.
