Windows Controls leak wind
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Hy-Bird, Jan 25, 2010.
  1. Hy-Bird
    Hy-Bird Junior Member
    69
    Does anyone have this problem with your Prius leaking wind inside the car while on the road? The driver side and passenger wind coming in from the window controls. Is my car defect???:(
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I've owned other vehicles which did that at highway speeds, even an Acura TL Type S.
    I think this was mentioned in a thread on here once before and others noticed it as well.
    Definitely not a defect...
  3. ken1784
    ken1784 SuperMID designer
    2,943
    1,383
    67
    Yokohama, JAPAN
    Is your vent setting recirculated?
    If so, please try to switch it flesh outside air.
    The positive cabin air pressure avoids the feeling of the leak wind.
    Ken@Japan
  4. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    you'll also feel the wind at door handle, speaker grille etc. too.
  5. Hy-Bird
    69
    I turn all air off in the car and circulated air. Yes, all windows are closed. The reason I don't like wind leaking thought the door panel is because couple weeks ago when I was on the freeway and I have circulated air and air off. I pass by a dead animal and I can smell right away. I'm going to bring my car back to dealership on Friday and see what they will say.
