Winter Weather
Discussion in 'Fred's House of Pancakes' started by qbee42, Jan 28, 2010.
  1. qbee42
    3,079
    For those in the warmer parts of the world, here is weather update. The following photo is from the webcam on top of the hardware store at Beaver Island, which is very close to where I live. A brief warm spell removed much of the snow, but today we are back to 9°F and high winds. Note that the ferry is frozen into the ice. Until the ice breaker comes in the spring, everything has to fly on and off of the island, which gets very expensive.
      File size:
      24.1 KB
      541
  2. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    It's too bad the rest of the lake doesn't freeze... then you could just truck everything in!
    But it could be worse... the Prius told me it was 0 degrees F on my way to work this morning :)
  3. qbee42
    3,079
    Some years it does, but it's an iffy thing. I remember awhile back when a house moving firm tried to truck a house over the ice to Mackinac Island. They lost the house and the truck. You pays your money and you takes your chances.
  4. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I'd show you pictures of Winter here, but you'd only be jealous. :cool:
  5. qbee42
    3,079
    More snow and BIGGER ships stuck in the ice?
  6. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    No, no, no...it's not a fairy frozen in the ice, it's a person of alternative lifestyle. what?....what's that?.....Oh, a FERRY!
    Never mind!
  7. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Uhhh....yeah, that's it. :rolleyes:
    Water freezes? Like, outside? :p
  8. octavia
    octavia Active Member
    968
    137
    Beautiful Oregon
    We've had some fabulous days... sunny and warm. Spring preview!
  9. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Preview? No, it's here. The trees are in bud, the tulips are out of the ground, and the forsythia has blooms on it.
  10. qbee42
    3,079
    More ice on the lake today:
      File size:
      25.6 KB
      405
  11. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Another few weeks of that, and you'll be able to go ice sailing! :)
  12. qbee42
    3,079
    How true. The inland lakes are good for that right now, but not the big lake.
  13. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Until then, you could always use the snowmobile. Apparently they work on liquid water, too. ;)
  14. qbee42
    3,079
    As long as you keep them going fast.
  15. qbee42
    3,079
    Here is the same webcam view after dark. The bright light across the harbor is the harbor lighthouse.
      File size:
      22.4 KB
      456
  16. icarus
    icarus Senior Member
    4,884
    976
    earth
    In North Western ON they're -26 at home right now. Warm compared to the week after Christmas, when we didn't see -15 for almost 2 weeks. We don't generally drive over the ice, as we are 25 kms from the nearest plowed road, so we ski-doo in. (We live on one island, our only neighbours live 4 km down the lake on another island). Occasionally we need to move heavy stuff over the ice, so we plow and pack the trail to the shore over the course of the winter, and then do the big hauls in March before the ice begins to melt. What most folks don't realize is that snow on the lake creates all kinds of problems. Consider this, the combined weight of any snow on the ice, forces the ice down, bringing the water up through the ice. The result is the water gets into the snow causing major slush. Because the snow insulates this shush ice often won't refreeze all winter. Depending on the winter, we may have 30" of blue ice, with little slush ice, making for very safe travel. Other winters we may have 12" of blue ice with 24" of slush ice on top. This can be very dangerous. You can break into that 24" of watery slush and get stuck quite easily in a snowmobile. If you are far from home, the results can (and have been deadly).
    So, if you have ever watched ice road truckers, the big reason they plow the ice is to allow the ice to freeze deeply with no snow on top, and to keep the slush at bay.
    Since we only have the two families we don't bother plowing, we just run the ski-doo. There are whole series of engineering specs for ice. The weight capacity increases exponentially with thickness. If 6" will support 1000 lbs for example, 12" might support 15,000 lbs. (I have driven 85,000# track hoes over the ice before). The biggest issue with ice driving is critical speed. As you load ice, you push it down, and as you move, you create a pressure wave. If you go to fast, as you near the shore, that wave can be big enough to break very thick ice. Generally ~15 mph is suggested for heavy loads.
    I am currently on the RECORD WARM west coast right now. (Record warm for the entire month of January! Lest anyone think that all this talk of ice suggests that global warming is a hoax.
  17. icarus
    4,884
    976
    earth
    Pics from our front door,
    Timber wolf on the ice,
    Second, I call, waiting for spring!
  18. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    It's almost 10pm, and still 48F outside.
    We've had rain.. a few days of weak sunshine.. a little more rain... some partly sunny... fog and rain...
    It's great. I now drive 112 miles round trip per day, over a mountain ridge, to and from work. No ice to deal with :D
  19. icarus
    4,884
    976
    earth
    Maybe no summer water (or less for sure) Winter snow pack in te cascades is ~50% of average. I skied Baker today, and there is NO SNOW until just at the base elevation ~4500'.
  20. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    As nice as it is to enjoy a winter without snow (ok, we had a dusting in December) the long term worry is water. It's hard to imagine that being a concern in the 'wet coast' rainforest, especially this time of year, but the mountain snowpacks water vast areas all summer long. Winter seems to be getting shorter, and the local mountains are unusually bare at the moment. We've had summer water restrictions for several years now, and low water flows combined with higher temperatures are hastening the demise of the salmon that are critical to the food chain.
