Turn Off Nav Peacefully
Discussion in 'Gen 3 Prius Audio and Electronics' started by Frihet, Dec 29, 2009.
  1. Frihet
    Frihet New Member
    Ohio
    Does anyone know how to turn off the Nav system while driving without beating it to to death with an emergency escape hammer?
    Thanks!
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    say "suspend guidance"
  3. risingsun
    risingsun seeker of the way
    186
    30
    Prescott, AZ
    Push the Audio button and listen to the music... XM or iPod preferably. :)
  4. Frihet
    Frihet New Member
    Ohio
    Tried that, but the lady kept telling me to do a u-turn. Telling her to "suspend guidance" seems like a reasonable solution. I guess I'm old fashioned. I would have had no trouble with an on -off button.
  5. Frihet
    Frihet New Member
    Ohio
    OK, good. Who'd a thunk it.
    Thanks! I'll go shut the lady up now.
  6. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    You would first have to hit the TALK Button on the steering wheel befoere saying "Ssuspend Guidance".
    Or you can hit the DEST button, and hit the DELETE DEST button at the top of the display....
    You won't have to listen to anyone but your passenger then! ;)
  7. Tideland Prius
    16,588
    or use "Delete all destinations"
  8. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    press DEST button, at the top hit "Delete Destination", then "Yes" (from memory, I think that's the process)
  9. Frihet
    Frihet New Member
    Ohio
    I have not tried this yet, but I think it is as close to an off button as I'll get. I am assuming this will not actually delete my "Home" preset if I do it while navigating to home. I'll try it today. I bought a Honda Insight in 1999 (2000 model). I chose it because I thought the gen 1 Prius was too complicated. I still do (think it is too complicated), but my son's 127,000 mile gen 2 seems to be very reliable, complexity or no, so we took a chance.
  10. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    It should NOT delete your home destination permanently. At least it has not on mine. :)
  11. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Since noone has mentioned it, I'll add that you can also simply suspend the guidance, which is often useful when you change routes and the nav lady is being slow about changing to the different route (i.e., trying to send you back to the original route). It's a little hidden on the 2010, and I don't remember the exact sequence, but it involves hitting the onscreen route button, after which you have the option to suspend guidance.
  12. dksachdev
    dksachdev New Member
    Vienna, VA
    I have the same question on Prius 2009. The manual does not say how to suspend guidance before you reach the destination; very frustrating. Would appreciate help
  13. Tideland Prius
    16,588
    Did you read Efusco's post? (#2)
  14. Vancouver
    Vancouver New Member
    42
    Vancouver
    The sequence is this:
    1) Press audio button on steering wheel.
    2) Say, "Pause guidance"
    You can then resume when you want with this:
    2) Say, "Resume guidance"
    and it will recalculate from your current position to your destination.
    Voila!
  15. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    What I've experienced with using the "suspend guidance" function is that guidance automatically resumes after a key cycle. Additionally, if I go to input another destination, it will add it to the "route" in progress instead of the new destination being the only destination. "Delete Destination" is the function I use.
  16. Vancouver
    42
    Vancouver
    Yes. That is very true. I only use suspend guidance when I want to take a quick detour, or temporarily have the lady stop bugging me, but I know I still want to get to the original destination. If I just want to stop all guidance and not go back to that same destination, then I just give the voice command, "Delete all destinations" and it zaps them all quickly.
  17. Tideland Prius
    16,588
    You can tell it to replace the destination, instead of add to, right? Unless you mean you input one via voice?? If so, then I'm not sure.
