Early 2010 Prius Brake Recall-real
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by efusco, Feb 4, 2010.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,195
    Nixa, MO
    Just heard on the Today show that pre-January build 2010 Prius are being recalled for a "brake problem". Haven't found a pertainent link with details yet. Will update thread when I do.
  2. GreenGuy33
    GreenGuy33 Active Member
    534
    29
    Rhode Island
    I watched a segment on the Today Show around 7:10am EST and was waiting for the word RECALL, but never heard any official words from Toyota, only questions whether there would be one.
  3. johalareewi
    johalareewi Member
    393
    44
    uk
  4. Politburo
    Politburo Active Member
    971
    208
    I saw the 7:10 segment and also the guy from Consumer Reports who was on a bit later. The CR guy was very fair to Toyota, pointing out that there was a small number of complaints (and no injuries), and he thought that it was more of a perception than safety problem (as has been debated ad nauseum here). He also said he would continue to drive Toyotas and that CR would re-recommend Toyotas after the whole thing passes over.
  5. DotComCTO
    DotComCTO New Member
    Westchester County, NY
  6. GreenGuy33
    534
    29
    Rhode Island
  7. web1b
    web1b Active Member
    817
    52
    Sounds like they misspoke or you misheard. Maybe there should be a recall, but I would be surprised if a recall can be set up so quickly as to be announced today.
  8. GreenGuy33
    534
    29
    Rhode Island
    If it is a software issue, why not tell customers that they will correct it at their next scheduled maintenance?
  9. octavia
    octavia Active Member
    968
    137
    Beautiful Oregon
    Slow down guys. :)
    This is the downside to "breaking news" and "up to the minute". Takes the information chain a few to get everyone caught up.
    Let's give it a day rather than going back and forth all day.
  10. web1b
    web1b Active Member
    817
    52
    Maybe that is good enough, but they need to say something about it soon. The gas pedal issue causing deaths on the other Toyota models is going to keep them busy, so there may be some delay before they can focus more attention on the brake issue since people aren't dying over this problem.
  11. qbee42
    3,079
    Or just post a hex file and some instructions. :D
  12. GreenGuy33
    534
    29
    Rhode Island
    CNN just reported that the US HTSA is investigating the 2010 Prius brake issues.
  13. MarkUK
    MarkUK New Member
    Gloucs UK
    I hope the recall will also be in the UK - currently, they seem to be denying all knowledge here.
  14. Rhino
    Rhino New Member
    460
    U.S.A.
    They probably have to field test any reprogramming. The last thing they want to do is for the reprogramming to fail. Imagine headlines, I took the car to be reprogrammed and not it is now a brick. You cannot underestimate the number of things that can go wrong - the car could be running when reprogrammed, the computer may run out of battery, the cable can be misplugged and fry the memory, what if the tech hit the wrong button, is your car bricked. What is someone pressed the remote?
    What if the car is reprogrammed but it don't test out? Do you let the customer leave - could be dangerous.
    What if some guy comes in with 20 inch rims, will the program work? Should you refuse? Is reprogramming an admission by Toyota that the modification is OK?
    What if someone have a heavily modified aftermarket plug in? Do you refuse?
    When you reprogram a phone, the worse that can happen is the phone is dead. If you mess up a car, somebody could be dead.
    So even if they have a program, it will take some time to establish all the criterias.
  15. radioprius1
    radioprius1 Climate Conspirisist
    1,355
    155
    Iceland
    This sucks. I hope they issue a fix quickly.
  16. zencat
    zencat Junior Member
    98
    Studio City, CA
    So what's the recall protocol? Mine is definitely an early 2010 Prius and I believe I have felt the problem. Am I going to get something in the mail, or do I just call and make an appointment?
  17. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I suppose you could wait for a letter from Toyota, but I decided not to. After reading the Toyota press release announcing the recall, I logged into my Toyota Owners Online account, where the recall was listed. I took the car in last week and got the ABS ECU reflashed.
