Battery pack for plug-in prius is obsolete
Discussion in 'Gen 3 Prius Main Forum' started by CivicQc, Feb 9, 2010.
  1. CivicQc
    CivicQc The world needs more prius
    233
    99
    Planet Carbon
    Shocking title? (I thought this would be a nice change from the brake issue).
    I read the following article: Why the 2010 Toyota Prius Doesn't Have a Lithium-Ion Battery - Green Car Reports
    They say:
    Comments?
  2. Tom183
    Tom183 New Member
    652
    65
    Maine
    Here's my favorite - the author truly reaches the ideals of good journalism:
    Using something which works well is a "stumble"? That would imply that every company still using internal-combustion engines is "stumbling"...
  3. brandonpa
    brandonpa New Member
    49
    Pennsylvania
    Can someone explain what the point of plugging in this car is? Aside from an engine block heater why? Ok, so that battery is charged when you start the car but what will that get you, especially when the car charges the battery itself?
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Look at it the other way, if it takes 10 miles to recharge the HV Battery for 1 mile of EV, then 13 miles of EV would take 130 miles to recharge. The Plug-in can eliminate that 130 mile mileage hit, boosting your MPG.
    This would help that class of owner who often need less than a 13 mile range and can use their car as an electric vehicle normally, yet sill have a Prius when they needed to go over 13 miles. (I rarely wish to drive my Prius less than 50 miles each way, so I am not a target customer)
  5. GrumpyAndOld
    GrumpyAndOld New Member
    55
    Seatle
    That makes sense.
    It explains why the plug-in pack is so heavy and of such low capacity.
    The good news is the Nimh works well on the prius. Let's hope that some of them Korean Batries in the Volt, or the JCI-Saft Lion work out better. Panasonic EV may really need the Sanyo techonology too.
  6. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Irony is that according to the specs in the Toyota NCF, the plug-in LiIon battery pack has a lower Amp-hour capacity (3 hour capacity - 5Ah) than the NiMH (3 hour capacity - 6.5Ah), but makes up for it with higher voltage (345v vs. 201.6v).
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I think you misunderstood the point.
    The current PHV Prius being tested now is using the obsolete expensive pack. When the "tri-metal" battery is ready for production in 2012, PHV Prius will be available for consumer.
    This explains the shocking cost of the current PHV Prius. We'll have to see how much cheaper the "tri-metal" battery pack will be.... especially compared to NiMH.
    2012 is also when the more affordable smaller Prius will become available. I hope it will use tri-metal lithium battery.
  8. CivicQc
    233
    99
    Planet Carbon
    It is true that the article can be interpreted that way. If that's the case, it means when the plug-in prius is available next year, the tri-metal battery will not have been tested as much as the one in the current PHV Prius. It may also mean that in the current demonstration program, they are collecting data related with user's habbits rather than with battery durability. They can then presumably use the data in their sumulations to test the tri-metal battery in their lab, simulating real world usage.
