Temp Display went Metric for a While
Discussion in 'Gen 2 Prius Technical Discussion' started by TonyPSchaefer, Feb 12, 2010.
  1. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    I have three threads indicating that it is not possible to change the temp display from F to C. At least, not intentionally. Yesterday, When I started up Priapus, I noticed that it was -2ºC instead of 28ºF.
    http://priuschat.com/forums/gen-ii-...ay-changed-celsius-fahrenheit-2008-prius.html
    http://priuschat.com/forums/gen-ii-prius-main-forum/42957-converting-metric-display.html
    http://priuschat.com/forums/gen-ii-prius-technical-discussion/36889-us-metric.html
    For those who don't know, the sheep is my way of marking the picture as mine. As in, I didn't search the internet for it and when you see it posted on another forum you'll know where it came from.
  2. dogfriend
    7,512
    1,190
    Carmichael, CA
    I'm sorry, what was the problem again? I was distracted by the sheep. :madgrin:
  3. Tideland Prius
    16,553
    It was messing with you, hoping you'd think it's -2F outside.
  4. TonyPSchaefer
    14,816
    2,500
    66
    So is it just me? This isn't the first time this has happened but the first time I was able to grab a picture.
    Doesn't anyone else think this is odd?
  5. patsparks
    10,664
    567
    Adelaide South Australia
    How good is that? You Prius knows metric is better than imperial measurements. Unfortunately the MPG display is a bit slow to catch on.
  6. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I don't see a problem with the temperature display either. :D
  7. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Personally, I think it's a baaaaaaaaaaaaaad thing.
  8. Patrick Wong
    18,200
    6,502
    This is quite odd. I take it that the display is switching back and forth on its own?
    I posted 12V battery photos on one of the Yahoo Prius groups as well as on PriusChat. I recently noticed a Russian Prius website poster "borrowed" a photo. Once it's in the public domain, who knows where a photo might travel.
  9. TonyPSchaefer
    14,816
    2,500
    66
    The sheep was introduced in reply to a photo I posted a couple years ago. Some loudmouthed newbie was arguing that the Prius was incapable of mileage above 60mpg because he was incapable of it himself. I posted a picture of my 73.3mpg tank. His reply was to accuse me of finding that image on the internet and claiming it as my own.
  10. Patrick Wong
    18,200
    6,502
    Back to your issue of C vs. F temp display. My guess is that the MFD has a soldered jumper on a circuit board that enables F temp display (with default being a C display). The connection is intermittent, which allows you to see a C display from time to time.
    This is good news: Your Prius' market value can only increase, as it has become a unique vehicle equipped with this unusual feature! :rolleyes:
  11. Tideland Prius
    16,553
    Guess mine's a permanent bug, tony ;). no I've never had it switch to fahrenheit. Do note that the temperature display is calculated in celsius (that's why it skips certain numbers in fahrenheit)
  12. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Isn't it just programmed in to display F in the US and C everywhere else? Is it something the dealer can change when they plug their computer in?
    I'm not a great fan of metric but the one metric measurement that really does make sense is Celsius. We used F here until the early 1980's and some people often use F in summer and C in winter. I suppose it's what you get used to.
  13. Tom Banjo
    Tom Banjo New Member
    62
    South Florida
    Maybe outdoors it is F sometime and C other times, so it is just reporting the actual temperature.
    J/K ... it does sound like an intermitant connection ....
  14. TonyPSchaefer
    14,816
    2,500
    66
    It just occurred to me that some of the temperature sensors we make (where I work) have physical resisters that determine the temperature scale. To switch from F to C is a simply matter of snipping the wire thus removing the resister. This triggers the switch.
    Does anyone have a wiring schematic that might show something similar.
  15. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    A related question. Does everyone see the drop down banner across the entire width of the MFD (at the top) announcing the outside T being 37 F?
  16. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    Yes. The 'snowflake' graphic reminds me strongly of the aliens featured in the Outer Limits episode, "Behold, Eck!"
    That's my usual response when I see it.... behold, Eck!
  17. Tideland Prius
    16,553
    snowflake symbol. On 2004-2005 models, we got that AND the snowflake icon on the dashboard.
  18. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    I thought we didn't get the snowflake icon in Canada.... I didn't.... I guess only in the 2010?
  19. vertex
    vertex Active Member
    672
    144
    new york
    2018 Prius Prime
    I get the 37 degree message, no snow flake, 2006
  20. Tideland Prius
    16,553
    2004 and 2005 models only.
