touring package 2
Discussion in 'Gen 2 Prius Main Forum' started by cvincent, Feb 20, 2010.
  1. cvincent
    cvincent Junior Member
    76
    arizona
    i am looking at a 2008 touring with package 2 and a 2009 base with package 4
    can anyone tell me what i am not getting with the package 2
    these packages are very confusing
    thank you
  2. cvincent
    76
    arizona
    did more research, someone correct me if i am wrong, but it should have everything but nav and leather in the p-2 on the touring
    thank you
    probably buying this today
  3. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    When you're checking out a used Prius, make sure you check out the eBrochure for that model year. The eBrochures describe and list all the standard equipment and option packages.
    Here are all the eBrochures from 2002-2009:
    [​IMG] 02_prius.pdf
    [​IMG] 03_prius.pdf
    [​IMG] 04_prius.pdf
    [​IMG] 05_prius.pdf
    [​IMG] 06_prius.pdf
    [​IMG] 07_prius.pdf
    [​IMG] 08_prius.pdf
    [​IMG] 09_prius.pdf
    Also, watch out for people advertising "Touring" Prius. I've heard that people frequently lie or are mistaken when they claim they're selling a Touring.
    Note that ALL Touring Edition Priuses will have the following equipment at minimum:
    - Front HID Lights
    - Front Fog Lights
    - Larger Spoiler
    - Tuned Suspension (thicker front and rear stabilizer bars, different rear shocks and springs)
    - 16" Wheels - which is the easiest way to tell if it's a Touring (note that the OEM Touring tire was the Bridgestone Turanza EL-400 in the 195/55/16 size). Here's a picture of the Touring wheel cover and the Touring wheel:
    [IMGLINK]http://priuschat.com/forums/attachments/gen-ii-prius-main-forum/18597d1252962401-16-oem-touring-edition-alloy-wheel-set-sale-priuswheeldual.jpg[/IMGLINK]
  4. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    It is really unfortunate when unscrupulous sellers try to 'inflate' the car to something it is not.
  5. cvincent
    76
    arizona
    thank you those really helped
