More Brake Dust Since Recall
Discussion in 'Gen 3 Prius Technical Discussion' started by GrumpyCabbie, Feb 22, 2010.
  1. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Had the brake recall done on my car last Tuesday and have since done about 650 miles. Was washing my wheels today and noticed that the brake dust on the fronts was really bad.:(
    Now I've done 10,000 miles in my Prius before the recall and use the car in heavy start stop traffic so I use the brakes hard but have never seen so much brake dust as I have since the recall update.
    Is this just a coincidence or is it something to do with the recall? Anyone else had similar experiences?
  2. bwilson4web
    16,195
    Interesting ... we had rain yesterday and for the first time, I heard brake pads on rusty discs. ... Hummmm, maybe I won't put up an Ebay listing in 2020:
    "Original 2010 Brake pads, 200,000 miles, barely used."
  3. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Maybe I'll hold off on the reflash until I know my brake pads aren't being wasted for nothing...
  4. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    In the meantime, you can aim for the back of a stalled truck you need to stop fast. :) Sorry; the devil made me say it.
  5. austingreen
    austingreen Senior Member
    13,671
    4,209
    Austin, TX, USA
    I doubt the software, but you may want to check your brake calipers. Any of the brake places should do it for free. If its a problem, I would think it would be under warranty even though its a normal wear and tear item.
  6. bwilson4web
    16,195
    In theory, we might see a change in brake wear. But this will take a while to show up. Worse backing out SSC-A0B to establish a baseline might be ... difficult.
  7. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    I should be able to see differences with my SGII and the friction braking XGAUGE, if any.
    I do know that on the original firmware, on my commute home from work in heavy stop and go traffic on city streets, the brake rotors are cold to the touch when I get home. I do try to max regen ... but it would be a bummer if the ECU is constantly mixing in friction when stopping.
