Engine and Cabin Air Filters
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jk823, Feb 23, 2010.
  1. jk823
    jk823 Junior Member
    98
    Los Angeles CA
    I went for a oil change and tire rotation (I'm at 15k miles) on my 2009 Prius and the guy suggested I replace both my cabin and engine air filters. They didn't look too bad, but I was wondering at what mileage does Toyota recommend changing them? I can't seem to find that anywhere...
    Also, is there a recommended store online where I can buy replacement products cheaply or should I get them at the dealer for the best quality?
    Thanks!
    John
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    The cabin and engine air filters are recommended replacements at 30,000 miles (Toyota Parts and Service). However, many people change them sooner. It really depends on your driving conditions and roads you travel.
  3. jk823
    jk823 Junior Member
    98
    Los Angeles CA
    Thank you so much! Mine look A LITTLE dirty, but not as bad as I thought they could look. Not sure what they should look like when they're due to be changed.
    Anyone have any ideas?
  4. firepa63
    1,761
    208
    Those filters are very easy to change yourself. Don't pay the dealer to do it.
  5. jk823
    jk823 Junior Member
    98
    Los Angeles CA
    I would do it myself. But what should it look like when it needs to be replaced?
  6. firepa63
    1,761
    208
    Dirty ... I don't know how else to explain it.
  7. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    The cabin air filter can be washed when it's dirty instead of replaced. If it gets holes or rips in it, it's time for a new one. A little bit dirty is fine - you can always vacuum off the debris and stick it back in.
  8. Patrick Wong
    18,200
    6,490
    Engine air filter: hold up to sun. If you can't see light passing through, then replace.
    Cabin air filter: can you stand to breathe through the filter given the dirt on its surface.
  9. taggart
    taggart Member
    249
    I changed both of mine at about 18,000 miles. They were dirty, but not filthy, in my opinion.
    I've always changed air filters on my vehicles a little sooner than recommended. Seems to me it's a low cost way to keep the engine running efficiently and not put any undo stress on it. Just my way of doing things.
    I purchased both on Amazon and got free shipping and no tax. Another reason to do it early, I guess. You can wait for the order to arrive and don't have to pay "retail" just because you need it now.
  10. larry9901
    larry9901 Junior Member
    44
    michigan
    If it looks like this, its probably time to change!
  11. Patrick Wong
    18,200
    6,490
    Did you ever find the mouse? :p
  12. richard schumacher
    7,664
    1,042
    United States
    Just one thing: be certain to note which way they were facing when they come out so that you install them facing the right way. It's tempting to install the engine filter upside-down.
  13. larry9901
    44
    michigan
    Nope, But I went to Home Depot to purchase about 8 feet of 3"vacuum hose;)
    Hooked the hose up to the exhaust :eek:, then into the car.:eek:
    Tried to gas the suckers out:rolleyes:
    Good for them though, the car runs so clean there wasn't enough exhaust to get em out:confused:
    Just kidding!:p
  14. Patrick Wong
    18,200
    6,490
    The only thing worse than a live mouse in your Prius, is a dead one stuck somewhere you can't find it...
