Prius Camper that removes rear hatch
Discussion in 'Gen 2 Prius Main Forum' started by fastring, Feb 28, 2010.
  1. fastring
    fastring Junior Member
    60
    Saab Central - Features: Saab 900 The Toppola Camper
    Saab History Toppola
    Has anyone tried building a Prius camper that replaces the rear hatch? The 'ideal' solution that I'm looking for is what Toppola built for the Saab (see above or google "saab camper").:usa2:
    I'm not looking for comments about buying a truck with a camper...
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Well...I think it would really be pushing the max capacity, weight wise, for the car to put something like that on it. I get cold chills thinking what it will do to your Cd and fuel economy!
    There are some pop-up tents that attach to the hatch door that would work just about as well without the weight or aerodynamic hit. Let me see if I can find a link.
  3. efusco
    19,891
    1,194
    Nixa, MO
  4. hyo silver
    hyo silver Awaaaaay
    15,266
    1,603
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    How about comments on packing a tent in your Prius? :)
    Then you can take it with you, and see things you can't get to in a car.
  5. fastring
    60
    Yah, looking for something fixed so that I can pull over and sleep on the side of the road, like in an urban environment. At somepoint, I'll see how hard it is to remove the rear hatch and will go from there. Will probably have to try making something.
  6. hyo silver
    hyo silver Awaaaaay
    15,266
    1,603
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    In that case, would folding down the rear seats and rolling out an air mattress work for you? Window tint would afford some privacy.
  7. cheeper
    cheeper Member
    154
    Greene Co, NY
    When the rear hatch is open, little red light on dash reminds you a door is open.......what about that?
  8. Flying White Dutchman
    4,376
    313
    there is a switch that tells the prius it's open so just make sure you able to diconnected or hardwire that switch
  9. Leesakay61
    Leesakay61 New Member
    New Mexico
    My husband wants to modify a prius and put a truck bed on the back somehow.
    Maybe we'll come across a salvage Prius that we can experiment on..:rolleyes:
  10. fmi
    fmi Junior Member
    24
    Phoenix
    I'm sure you can splice into that, install a switch that will let you toggle it on/off.
  11. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    This camper is COOL! As for the issue of weight, I would assume they use stiffer springs in the SAAB version, which would be the thing to do with a Prius. Below is a link to something similar:
    EarthRoamer XV-JP
    I REALLY want one of these, but don't really know what I'd do with it...
