My "new" 2004 Prius with 110K miles
Discussion in 'Newbie Forum' started by lakatamia, Mar 3, 2010.
  1. lakatamia
    lakatamia New Member
    texas
    Hi all. I just purchased a 2004 with 110K miles on it! The car had one owner and it looks like it was taken good care of.
    I just found this site about 30 mins ago when I was searching for help with the FOB. Both of them run out of battery (or so it seems) a day after I bought the car! I'm wondering if I pressed the wrong button somewhere?
    Anything else I should be thinking about with a car with this many miles on it!
    Good to be here!
    Laka Tamia
  2. Jim Porta
    Jim Porta Junior Member
    86
    17
    Louisville, KY
    There's a button on the bottom front of the dash that disables the smart entry feature. With that disabled, you have to insert the fob into the dash to start the car and have to push the fob button to unlock the car. You may have bumped it with your leg.
  3. F512M
    F512M Member
    415
    Laguna
    Welcome to Pchat!!! This is a great forum to learn a lot.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Curious what you paid for your Prius. I have a Package 9 2004 with about 96k miles that I'll probably sell with about 110k miles this summer. Private sale or from a dealer?
  5. lakatamia
    texas
    It turned out that the battery on one of the FOBs went out. After wrestiling with it for a few minutes, I managed to replace it. All is good now!
  6. lakatamia
    texas
    Paid $9K at the dealer.
    How can I find out what "package" my car has? It only came with the owner's manual and it doesn't mention stuff like that.
    Thanks.
  7. Patrick Wong
    18,200
    6,491
    2004 Toyota Prius - Optional Packages
    If your car didn't have the 100K mile service where the engine and inverter coolants were replaced, I recommend you have that done now. The iridium spark plugs should be replaced at 120K miles. Also I suggest that you have the transaxle ATF replaced now although that is not listed on the scheduled maintenance guide.
  8. F512M
    F512M Member
    415
    Laguna
    What does it cost to replace the batteries?
  9. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    In CARB state, 110k mile pack replacement will be free due to warranty. Out of 150k miles warranty, you can get a brand new pack under $2,000. Add the cost for labor replacing it. The old pack has $200 recycle bounty so take it to a dealer to offset the labor somewhat.
    Toyota lowered the price of the battery pack in 2008. They will likely to lower it again before your 2010 need a replacement in 2020+.
