2010 Prius wheels on 2005
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Oreynid, Mar 16, 2010.
  1. Oreynid
    Oreynid Junior Member
    Washington
    I've searched both PC and the web, but I haven't been able to find a specific answer. I know that both wheels are the same size (15x6), bolt pattern (5x100), and offset.
    The question I have relates to tire size. The 2005 wheels take a 185/65-15, while the 2010 take the 195-85/15 according to tirerack.com. I've done a bit of dabbling into minus sizing, but I haven't come to a proper conclusion.
    The reason why I ask is because I bent one of the wheels of my 05, and I need to either replace that 1 wheel, or get another set of 4 from someone telling their 2010 OEMs. The tires on my current wheels are 185/65-15, and are perfectly good, so naturally I'm not going to spring for new set of tires just to change wheels :D
    Thanks!
  2. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    While I can't tell you of personal experience at GenIII wheels on GenII, I can tell you that my winter snow tires for my GenIII (in the correct GenIII size) are on GenII wheels, and I have had no problem.
  3. bretaz
    bretaz Member
    475
    52
    Surprise, Arizona
    Does anyone have pics of the 2010 15s on a genII?
  4. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
    Look right above at walterm's post
  5. BrettS
    BrettS Active Member
    290
    136
    Orlando
    I'm not entirely certain what you're trying to do. The wheels are the same size, however, the tires for the 2010 are much bigger (the diameter is almost 4" bigger). If you want to take your existing Gen II tires and use them with Gen III wheels you'll be fine because the wheels are the same size. If you want to use Gen III tires with Gen II or Gen III wheels then you'll likely run into problems because of the large size difference.
    hope this helps,
    Brett
  6. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    Brett is correct.
  7. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
  8. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Lots of us are using 195/65 R15's on our G2. H
  9. BrettS
    290
    136
    Orlando
    That makes a whole lot more sense. I based my calculations off the numbers above because I was in a hurry and didn't have time to look it up, but I was having a hard time believing that the Gen III tires were that big.
  10. sktn77a
    sktn77a Member
    303
    NC
    So you want to put the 185/65R15 tires from your old GII wheels on a set of GIII wheels? They will fit just fine (on the 15x6" rims) but I would probably just get a LKQ replacement GII wheel (and remove the trim rings if you want a new look).
