Run Away Prius a Hoax
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by GeoDesign, Mar 13, 2010.
  1. austingreen
    austingreen Senior Member
    13,675
    4,213
    Austin, TX, USA
    Those cameras might have shown if floor mats were involved.
    If toyota actually logged the braking data in the 2008 avalon, instead of just leaving a place in the log, we might know if that driver hit the brakes after a court order was served to toyota to read it. We do know that data is logged in the prius, and in the ny case it only took a senator to get toyota to read the data to show it was driver error.
    Toyota needs to at least get their reader data out of beta to be belivable in the area. They are doing far bellow the minimum you would expect from the largest auto maker. Tiny Hyundai has already put brake override in all of their electronic throttle cars, and mandate compliant logging in edr's of new models. It would be nice if toyota spent as much effort on logging as they do on PR, Lawyers, and regulators to say why they don't do it. I'm sure the hearings were a CTJM for the company and they may actually try instead of trying to obfuscate.
  2. vegasjetskier
    vegasjetskier New Member
    269
    29
    East Coast of Florida, USA
    I think you are the smoke screen promoter.
    You say the Exponent engineers are incompetent. What are your qualifications? Post your curriculum vitae.
    I doubt your ability to analyze any of these circuits based on your not understanding how a 500 hp car at full throttle would take longer to stop than if it were at idle and that you don't know the purpose of ABS.
    You are probably Malorn logged in under a different name.
    All of your posts are critical of the Prius or Toyota. I doubt if you even own one.
  3. wwest40
    wwest40 Member
    518
    Pacific NW
    2003 Prius
    I
    The only Toyota I own is a gen 1 Prius which our lead company engineer is the primary driver.
    Otherwise I am a Lexus fan first, Ford second, and Porsche 3rd. Or do I have those last two reversed..??
    The Ford folks over at GreenHybrid will attest to my being a Toyota "fan" due to my being so critical of Ford.
  4. chimo
    chimo Junior Member
    81
    Ottawa, Canada
    Well, I tried Googling you as per your suggestion above (which was inserted in bold into vegasjetskier's quote so it does not appear in this quote).
    Didn't look too hard but I found this on ecomodder, fwiw. Just one post in from the whole thread, there are several more posts above it.
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    You have made up your mind and your belief system is shut tight and nothing will be able to change that right? Everything you see will be tinted by your belief system. You have become a victim.
    Would a link from US government site rather than from Toyota make a difference either Exponent is building a PR for Toyota? I don't think so. You are going to come up with a reason that suit your belief system.
  6. wwest40
    wwest40 Member
    518
    Pacific NW
    2003 Prius
    I
    I only got as far as figure 4 of your linked document. I didn't recognize the chart in the figure in relation to my own memory of the same representative chart in the various factory documents.
    So I went and checked for each of the vehicles they reference as being represented by the chart.
    They do not compare in any way that would allow anyone to make comparitive judgments.
    I cannot imagine why someone would have taken such liberties with the chart, makes all the following information virtually worthless.
  7. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    As "Christ" from ecomodder said: Ok - I give up.
  8. Iceman123
    Iceman123 New Member
    123
    NY
    "Embedded systems are nothing like a PC or cell phone. And even then, I have never had a system failure on a PC or cell phone that wasnt caused by a 3rd party software ins".
    Hmm, a professor contradicts your opinion..see report on electrical interference!
    Questions Remain in Auto Accidents - FOXNews.com
    Martha Mccalum Is a hot mama !
    "I got a flash drive in the mail to update my firdge's firmware not too long ago... Wake up buddy, microcontrollers are everywhere".
    So what update did you get ?...Star shaped Ice cube makers..An update that stops bacteria growth ?...What possible update can you get for a sold fridge ?, other then fixing a flaw caught after selling the product the public ?..Updates on already sold items, should be bonuses and not corrections.
  9. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    It is a fox news clip, which is already a contradiction. Not worth intelligent people's time to even view.
    The update allowed the firdge to display more image formats that it previously could on its 7" touch panel display.
  10. vegasjetskier
    269
    29
    You said: "The wiring insulation breakdown or resistance, nor the connection contact resistance or breakdown isn't the subject matter any knowledgeable engineer would first address. Engineer knowledgeable of integrated circuit design and fabrication anyway." Italics added by me.
    Sounds like you're calling them incompetent to me.
  11. vegasjetskier
    269
    29
  12. Iceman123
    123
    NY
    ...........Thanks I couldn't figure out the possibility.
    If you don't like the Fox report ..How about this report 4 months ago from ABC, before the supposed Sikes hoax ...Look at the graph, when Toyota went electronic.
    [ame=http://www.youtube.com/watch?v=N-wD9MkaL3Q]YouTube - Are Toyota's Accelerators Out of Control?[/ame]
  13. bwilson4web
    16,217
    Well that convinced me . . . I must be dead.
  14. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    "50% braking" is *NOT* a number I ever said, don't attribute things
    to me wrongly. I said "meaningful braking" when recounting my own
    Prius "override" testing, as a qualitative point at which drive force
    was removed. It wasn't a whole lot of meaningful, either, but still
    enough to drag all the hydraulic brakes and make plentiful heat.
    The error-trigger voltage between the pedal leads *is* 0.4V in the
    Prius as of '04. Maybe not some other, perhaps earlier, Toyotas.
    Gilbert is a buffoon who couldn't figure out how to fake out the
    ECT controls in the other cars [thus, it took Exponent to do it
    correctly later], and at this point I think all of this pedal-leads
    nonsense is barking up the entirely wrong tree.
    wwest, what am I supposed to google for to find your theoretical CV?
    "wwest40" only returns a few priuschat links, much of it in all of
    the foregoing. It strikes me that your practical street knowledge of
    the second and third gen cars doesn't match what you're trying to
    pass off that you know.
    _H*
  15. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    Wow, I can't believe how much effort you guys put into trying to argue with obvious trolls! Just ignore them!
    Sikes has been proven to be a desperate man trying to cash in on the hysteria.
    The lady in NY confused the accelerator with the brake.
    Kennedy was killed by Oswald.
    Man landed on the Moon.
    :D
  16. Insight-I Owner
    Insight-I Owner 2006 Insight-I MT + 2011 Prius
    505
    100
    Essex, CT
    NO, please don't!! Troll-baiting, the new sport! Watching them build incredible shimmering edifices of improbability based on paranoid conjecture far surpasses any TV show in entertainment value.
  17. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    So, a couple of professors who moonlight by testifying in lawsuits against electronics folks have convinced you. Sounds like the same notion that leads people to say the earth isn't warming up at all, or if it is, it ain't our fault- a couple of paid hack scientists and problem solved.
  18. robbyr2
    robbyr2 New Member
    1,198
    149
    Commerce City, CO
    Old news. Who gave ABC, Fox, CNN, CBS, etc their information? It's journalism by press release from the product liability lawyers. Supported by shills with degrees. OMG, a real professor? There are a few thousand of them around I think. And like most people, money can help them make up their minds.
  19. wwest40
    wwest40 Member
    518
    Pacific NW
    2003 Prius
    I
    Yes, I suppose some might see it as incompetence, but I see it as a "smoke screen" or magic trick, "look over here, not where the action is".
  20. qbee42
    3,079
    I've had the same problem. For example, I made a post a long time ago talking about the accelerator pedal mapping for the various power modes in the Gen III. We were told that the differences were in the first half of the pedal travel, and mostly the same in the bottom half. Once I posted the "half" comment it became gospel. It's only roughly the first half, but the figure is cast in stone now.
