What's with the Prius's hub caps?
Discussion in 'Gen 3 Prius Main Forum' started by Skoorbmax, Mar 28, 2010.
  1. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    I got what is probably a bogus explanation from the sales guy and I did try and google. Why is it that this car has hub caps over alloy wheels? I've never seen that before on another car and it doesn't seem to be for aero reasons.
  2. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    There are some on here who feel the alloy rims are butt ugly, while others love them. You decide
  3. vegasjetskier
    vegasjetskier New Member
    269
    29
    East Coast of Florida, USA
    Improved aerodynamics.
  4. Skoorbmax
    2,641
    265
    Western NY
    Surely it's not just an optional addition for those who love or hate the alloy wheels? Do other vehicles do this? Salesman told me it's to protect them but that's like a plastic cover on a couch that is not see-through. It makes no sense. You don't put on a hubcap covering up wheels underneath to protect them just as you don't put an opaque screen over a painting to protect it.
  5. mjrauma
    mjrauma Junior Member
    35
    Houston, Texas
    2018 Prius
    They're just shipping covers designed to protect the wheels during transport. Feel free to discard them. :D
    Mike
    2 people like this.
  6. namasteflc
    namasteflc New Member
    47
    Georgetown Md
    I finally found some low cost 'plugs' to fill the center hole in the wheels. They're all brass and 'friction' fit into the openings. Four plugs for about $ 7.00.
  7. Skoorbmax
    2,641
    265
    Western NY
  8. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    Link?
  9. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    kenoarto likes this.
  10. fuzzy1
    10,383
    No.
    This is the first (fossil-fueled U.S. market) production car that has ever needed to use just about every little trick they could squeeze in to get that headline milestone of "EPA 50 MPG".
    For all other cars, that milestone has been just a hysterical fantasy.
  11. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I'm not so sure I buy the aerodynamics aspect of it. There's probably much more designs they could have used if they wanted to, and at that point, why not just use a standard, cheap alloy wheel with cover? I always considered it more of a protective cover. Prevent a lot of the dings from curbs, pot holes, rocks, etc that get flung up. But then, I go back to the using a standard, cheap wheel with cover again.
    I wouldn't be surprised if it was done mostly as a design aspect. The wheel design looks better than the cheap wheels w/ hubcaps but the cover may serve as a protective cover for that.
    I think it falls into the category of questions, with "how many licks does it take to get to the tootsie roll center of a tootsie pop?"
  12. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    The "improved aerodynamics" are more than offset by reduction in weight.
  13. BlizzardJ
    BlizzardJ New Member
    108
    SG, CA
    If the wheel covers are intended to improve aerodynamics and thus increase MPGs, I have yet to see it. I've had mines for a month and a half now, and I took the covers off about three weeks ago. My MPG calculations (based on miles driven divided by how many gallons of gas I put in to top off the tank) have not changed since the removal.
    I suppose it really comes down to a question of aesthetics. Some like that the spokes of the covers "flush out" at the edge of the rim (like pretty much what all wheel covers do) and give the perception that the wheel diameter is larger. Some (myself included) like how the thin spoked alloys look. To me they look very JDM-ish, I'm often tempted to get them powder coated dark bronze.
  14. Tideland Prius
    16,537
    Every bit counts, right?
    the wheel covers, the curve in the roof, the underbody covers and spats, the mirror design, the smaller grille design, the "aero corners" etc.
    They could've gone with a full alloy wheel. You guys know how the HCH-II's alloys look like right? Yup.. solid block with pizza slices. You could have that or the Prius' design which gives you the option of two designs.
  15. BlizzardJ
    108
    SG, CA
    Absolutely.
    But on the same token it appears that whatever difference the covers make is very minuscule perhaps even negligible.
  16. Tideland Prius
    16,537
    Well remember that whatever the cover, umm... covers, that can be hollow in the alloy wheel design, thus saving weight that way. It's now a twin spoke design vs. the solid 5-spoke in the old Prius, so they've carved out a bit more metal that way.
    It's also a balance btwn aerodynamics vs. style. Of course the most aerodynamic design would be a full solid cover (basically like the HCH-II) but not everyone likes it. Stylish alloys tend to have a lotta gaps (mostly cause the spokes are thin). At least the Prius gives you the option of having them on or off... stylish alloys or aero covers? Your choice.
    With the HCH, well you're kinda stuck unless you wanna shell out for a new set of alloys.
    Interesting fact: The alloy design on the Euro Insight is different from ours b/c ours focusses more on aerodynamics (the EX model) vs. the Euro version which is more on design and thus less aerodynamic than the US model.
  17. sablanj
    sablanj Junior Member
    Guam
    I wish to purchase the plugs, do you have a link or toll free phone number???
    thanks
    JDS
  18. fuzzy1
    10,383
    Taken individually, many changes are minuscule and likely to be undetectable to regular drivers, masked by the large daily and seasonal variability.
    But taken together, they can really add up. My recollection, from just before the release, was that Toyota was struggling to get that 50 MPG EPA rating, which is based on far more precise and repeatable tests than we owners can possibly replicate.
  19. Skoorbmax
    2,641
    265
    Western NY
    I'm very glad the wheels on this don't look like the honda civic hybrid from a few years ago. I think that was the pizza slice look. Just did not sit well with me at all. It's a nice look on time trial bicycles but not on a car :)
    I appreciate the ongoing responses. So, it sounds like in great part it really is here by Toyota as an aesthetic option but presumably there is an aero impact but nobody can quantify it? Has an engineer from Toyota ever off-handedly commented about it anywhere to anybody's knowledge?
  20. colfacs
    colfacs New Member
    34
    louisiana
    They are there to control air flow to the brakes. :)
