Are these Bridgestones the same?
Discussion in 'Gen 3 Prius Fuel Economy' started by GrumpyCabbie, Apr 1, 2010.
  1. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I've recently changed my front tyres with what I think/thought were the same - Bridgestone B250's.
    However, since fitting these new tyres my mpg has dropped quite significantly. This has baffled me and I am taking the car to the dealers on Monday to investigate whether there is a fault with the car or whether the tyres are to blame.
    Now I thought the tyres were the same but upon closer investigate I noticed that the original tyres were Bridgetone B250 Ecopia's (made in Japan) and the new ones are Bridgestone B250's (made in Poland).
    Am I right to assume that these are actually two different type of tyre and that the Ecopia's are an eco tyre and give better mileage?
    Would appreciate your earliest comments as I see the dealer on Tuesday :)
  2. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    Other manufacturers are doing the same--putting out "regular" tires and "low rolling resistance" tires using the same name. For example, I have Goodyear Assurance FuelMax as Original Equipment--this is their basic low-rolling resistance tire. OK, tyre.
    However, there are other Goodyear Assurance Tyres that are not low rolling resistance.
    Thus you might want to check the UK Bridgestone website to see if the tyres called B250 Ecopias are different from those called plain B250s. I bet they are.
  3. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    As a comment, any new tire gets reduced mileage at first. I bet the same is true for tyres. :)
  4. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    lol, it's the old colour/color, labor/labour, Specialise/specialize thing isn't it. do not know why there are different spellings in the same language.
    I have done nearly 1500 miles on these tyres and the economy isn't improving. Am seeing the dealers on Monday to try and sort this issue out. If they're recommending the wrong replacement tyres to all the Prius's then Toyota are probably wasting their time designing an eco car for it to be messed up later.
    I have checked the UK Bridgestone website and they don't do a B250 ecopia, so don't know if they still sell these or whether they only sell the ecopia's in other countries. If they do still sell them somewhere in the world I could always order them.
  5. kgall
    kgall Active Member
    984
    152
    Grumpy,
    Here's a link posted by Boo in a thread about Michelin A/S tires in the Main Gen III Forum:
    When Round and Black Becomes Lean and Green
    They are tires rather than tyres because the article is about the American market.
    The article describes the following
    August 12, 2009
    Tires tested:
    Bridgestone Ecopia EP100 (Grand Touring Summer 185/65R15 88H)
    Goodyear Assurance ComforTred (Passenger All-Season 185/65R15 86T)
    Goodyear Assurance Fuel Max (Passenger All-Season 185/65R15 86T)
    Goodyear Integrity (Passenger All-Season 185/65R15 86S)
    Michelin Energy Saver A/S (Passenger All-Season 185/65R15 86T)
    Michelin HydroEdge with Green X (Passenger All-Season 185/65R15 86T)
    Yokohama dB Super E-Spec (Grand Touring Summer 185/65R15 88H)
    As you see, there is a Bridgestone Ecopia, but it has a different model name EP100 than yours.
    I'm going to bet that what you want to do is get low rolling resistance tyres, but that you won't be able to use US-oriented guides to find the best for you.
  6. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    You're right - the brands and models of tyre differ depending on country.
    I am still only getting about 42-43 (UK mpg) mpg [​IMG]
    I thought they seemed to be improving as they bedded in, but no I was still getting 42mpg on average. On a long run I managed 50mpg where I would normally have got 60mpg! I have today been to the dealers who thought they'd replaced the fronts with like for like Bridgestone B250's.
    It appears the B250's on the Prius as new and the B250's sold in the UK are COMPLETELY different tyres. Word of warning to UK (and maybe Europe) Prius owners - Do NOT replace with B250's - they are not the same. The Japanese version the Prius comes with is a B250 Ecopia (low resistance tyre) whereas the UK (made in Poland) B250 is an economy (as in cheap) tyre.
    Been in communication with my dealers since the tyres were changed two weeks ago as the mpg loss was worrying. Been to see them today and they have agreed to replace the new B250's recently fitted with some new Bridgestone ER300 Ecopia's to see if this will rectify my very poor mpg. To assist they also replaced the engine oil with 0w20 just incase they'd accidentally filled it at last service with 0w30. They don't believe they did but thought it a small costing to try and rectify the mpg.
    So, we shall see if the Prius will return to its super mpg or whether I now have an expensive car that gets the same mpg as a diesel Avensis. [​IMG]
